Simple mod for Photon 2
Coherence
Bend, Oregon
Easy mod to Photon 2, reorient the LED:
Just open it up and drill a tiny hole for one of the LED wires on switch side of case. Insert wire, bend appropriately along switch and reassemble (other wire goes to other side of batteries of course). A dab of epoxy seals the end up.
Replace the split ring on the end of the light and hang it from your jacket zipper - now it points in front of you and not down.
You now have a tent light that sits flat and does not roll (at all).
I have attached a patch of (hook side) velcro to the back. The mating (loop) side is attached to a lanyard, about the size of a shoestring. Wrapped around the head you have the lightest weight headlamp available.
