Hello all, I have decided to give your forum since you seem knowledgeable here about lighting.
I would like to know if it is possible to use artificial lighting to mimic natural sunlight in a room with poor sun exposure. The room is a building where heliostats/outdoor reflectors would not be an option.
While fluorescent lighting is bright while you look at it, a few bulbs does not provide the intensity to light up every corner of the room the way direct sunlight does. It also makes objects look white instead of giving it the warm glow as with natural sunlight and gives off a subtle flicker. Is this the best technology for this project or would LEDs and/or incandescents be better suited?
Does anyone have any suggestions on the type of lighting, type of bulb, color temperature, number and spacing of bulbs and fixtures or ballasts required to fill up a small room with artificial light that approximates natural daylight in a room with good sun exposure without blowing a fuse?
I was specifically wondering if a "virtual window" could be created on a wall using artificial lighting.
Thanks for any suggestions.
