Single AA EDC, Possibly High CRI
Raven18
Looking for a single AA programmable flashlight that can get decently bright. High CRI isn't necessary and I figure I would Have to break the budget to obtain it.
Quark QTA is on top of my list right now, it is slightly over but it fits most of my required parameters.
Any other options you guys would suggest?
____I would like to purchase the light in person from a brick and mortar store. I am located in ______________.
__X__This will be mail-order or Online (location doesn't matter).
2) Budget: An easy question, but you may change your mind after answering the rest! :)
____I don't know yet
____Up to $25.
__X__Up to $50.
____Up to $100.
____Up to $200.
____Up to $300.
____Essentially unlimited.
3) Format:
____I am not sure, please help me decide.
__X__I want a flashlight (hand held/self contained).
____I want a self-contained headlamp.
____I want a headlamp with an external pack/power source.
____I want a mounted light (typically for a bicycle or vehicle)
____I want a lantern/area light.
____I want a portable spotlight (it may have an external power source).
____Other ____________________________________________
4) Size:
____MICRO - Keychain size.
__X__TINY - Every day carry (2-4 inches).
____SMALL - Every day carry (4-7 inches).
____MEDIUM - Holster/belt ring carry. (>7 inches)
____LARGE - Big enough to need its own travel case.
____I don't know/I don't care.
5) Emitter/Light source:
__X__LED (known for efficiency, longevity, and compactness)
____I don't know.
6) Manufacturer:
__X__I want to buy a light from a large/traditional manufacturer that is ready to go out of the box.
____I would like a light from a specialty manufacturer (Possibly limited run/Custom).
____I am interested in assembling my own components. (for example a "host" or flashlight body from one manufacturer, and a "drop-in" emitter from another source).
__X__I intend to use "Primary"/Disposable Alkaline batteries based on the usual AAA/AA/C/D sized cells common to most stores.
__X__I intend to use "Primary"/Disposable Lithium batteries based on the usual AAA/AA/C/D and CR123 sized cells common to most stores (often a cold weather or long storage choice).
__X__I intend to use Rechargeable cells (NiMH or NiCD) based on the usual AAA/AA/C/D sized cells common to most stores.
____I intend to use Rechargeable cells based on less common formats (18500 or 18650 Li-Ion, RCR123, et-al).
____I want a light with an integrated rechargeable battery pack.
____I don't know/I need more information on power sources.
____I want a light that plugs directly into the wall (literally with prongs built into the light)
____I want a light that has a recharging adapter (your typical "wall wart")
____I want a light that snaps into a cradle (usually mounted on a wall)
__X__I want a separate/stand-alone charger (this involves removing the batteries to charge)
____I don't care
__X__I want to navigate a dark room or read a map (1-10 lumens).
__X_I want an indoor "blackout" light (15-50 lumens)
__X__I want to confidently walk around an unlit/unpaved rural area (60-150 lumens).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
____I want search and rescue type illumination (800+ lumens).
____SPECIAL NOTE: Burst/Turbo mode Category - There are several lights that will run at a super bright maximum for a very limited period (usually 5-10 minutes) and then will "step-down" to a lower level for thermal control. Check here if this is acceptable.
____All Flood: I am doing "arms length" tasks like reading and campsite cooking.
__X__Wide Flood: I want a defined flood area for semi-close tasks like after-dark campsite tasks or working on a car.
____Narrow Flood: I want a sharply defined flood area that will project some distance for tasks like trail walking.
__X__Wide Throw: I want a beam with a noticeable hot-center for distance throw and a significant amount of "side-spill". Good for rough trail hiking, search and rescue, and general distance work.
____Narrow Throw: I want a beam with a very tight "hot center" and minimal "side-spill". Good for distance viewing, fog, and looking through dense undergrowth.
____Turbohead: I want a far-distance projector with a sharply focused spot of light and minimal or zero side-spill. Good for extreme distance and impressing your friends.
__X__Less than 1 yard/meter (reading, other close work)
__X__Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
__X__5-20 yards/meters (check out a noise in the backyard)
____150+ yards (I am searching from a helicopter)
__X__30-60 minutes (I have plenty of batteries just ready to be changed)
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
____Not Important (A "night-stand" light).
__X__Very Important (Camping, Backpacking, Car Glove-box).
____Critical (Police, Fire, Search & Rescue, Caving, Survival).
____I don't know.
____Any size switch will do.
____I need a BIG switch (I'll be using gloves or have very large hands or coordination issues).
__X__I want a forward clicky (Helpful for momentary activation and signaling).
__X__I want a momentary switch (Predominantly for use with signaling and short bursts of momentary light only).
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today's high end lights).
____I want a remote switch (usually found on high-end bicycle headlights)
____I don't care.
____I don't know.
____A simple on-off with only one output level is fine for me.
____I want multiple light levels. (Some lights have 5-16 light levels.)
__X__I want a programmable light.
____I want a selector ring.
____I want a strobe mode. (Oscillating pattern to confuse/blind aka "Police Mode")
____I want SOS mode. (blinks in ---...--- emergency pattern)
____I want a beacon mode. (Regular flashes at full power to show location.)
____I don't care.
____I don't know.
14)Material/Finish/Coating
__X__Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today's higher end flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
____I don't care.
____I don't know.
15) Water resistance
____None needed
____IPX4 (Splash resistant)
____IPX7 (Waterproof to 1 meter/30min)
__X__IPX8 (Submersible to greater than 1 meter for 4 hours)
16) Storage conditions
____In house (temperature/climate controlled environment)
____Emergency kit (long standby periods)
____Automobile glove-box (wide temperature swings, long standby periods, critical reliability)
__X__Other__EDC_________________________________ ____
____"Hybrid" light (bright incandescent combined with long running LEDs)
____Pocket/belt clip
____Holster
____Wrist/Neck Lanyard
____Crenulated bezel
____Non-sparking, Intrinsically Safe (IS) for use in explosive environments
Quark QTA is 17% off until the 17th of March. Type "LUCKY17" in the coupon code to obtain the discount. Takes it from $63 to $52.29 including international delivery.
If you want to come in under budget, you can look at the Eagletac D25A clicky. It has a reverse clicky though, so no momentary light. The D25A I believe is the slimmest single AA light. The clip also allows for deep pocket carry.
I've heard lots of good things about the Quark and D25A. They seem to be the two most recommended AA lights.
FourSevens Quark models using AA are one of the slimmest flashlight for this category, simple UI, with momentary switch, with wide flood and throw and can run using AA or 14500 batteries. This would be a perfect choice based on your requirements.
The QTA is .86 inches wide vs .65 inches for the D25A, or 21.8mm vs 17mm if you prefer the metric scale. If you can live with the reverse clicky, the D25A is a strong contender. If you must have the forward clicky, the Quark is the way to go.
I have a few of both (Quarks and D25As), and both with HCRI N219s too :D - both are good choices and both are "programmable." Which one is better depends on what you will be using the light for. As an example, Quarks are far more versatile - batt chem and configs, for one - but if you don't intend to use that versatility, then a big advantage is lost. I'm personally not a big fan of forward clickies, or 2-modes, but I feel a little lost without the "momentary max" from any lower mode in use pseudo-feature (works just like car high beam flashers) of the Pro UIs.
I just pulled the Trigger on a Quark Tactical QTA!!!
Next Flashlight's I (eventually) want to get will be a V11r, SC600 MKII, and a HDS.
You made the right decision. Your next ones are all very nice and useful models. Keep buying more light . . . . . . . . .lovecpf
Anyway to tell which foursevens lights are part of the lucky17 sale? Without having to go through the checkout procedure on every light.
cut and paste from the email....
Mini MA
Quark QPL
Quark QTA
Quark QP2L
Maelstrom MMU-X
Maelstrom MMS
Maelstrom MM-X
Or only 21 cents more and 2day delivery if you have amazon prime!
I just received my QTA. Took Two days to get here.
Very nice light, but I have noticed the power regulation takes a short bit to work.
If I have it programmed for moonlight and turn it on, it is brighter for a brief moment then mellows down. Is it normal? I know my predator doesn't do that if it is on that mode.
Wait. What?
Are these AA Quarks with the N219 emitters? I just got the N219 modified AAA preon from Illumination Supply. Love the tint. Would love a Quark AA with similar LED... who makes those?
Wait. What?
It's an emitter swap I just received my QTA. Took Two days to get here.
If I have it programmed for moonlight and turn it on, it is brighter for a brief moment then mellows down. Is it normal? I know my predator doesn't do that if it is on that mode.[/QUOTE]
Normal.. I understand they all "pop" a bit on ML mode due to their large capacitors... (which I'm also told by a custom builder is one of reasons behind their LT reliability).
I have been looking for a similar light lately. Does anybody have any opinions on the Fenix LD12? I have also been looking at the Eagle Tac D25A Clicky and the Quark QTA. Any information on these would be great.
Check out Selfbuilt's write up on the Fenix LD12 before deciding on it. Seems like a great light, but his information might sway you away from it, http://www.candlepowerforums.com/vb/showthread.php?372607 Selfbuilt also has some great write ups/reviews of the other lights you mentioned, definitely worth doing a search for them.
Congrats! I just got a QTA too and love it so far. Don't forget that they have the deep pocket clip too. I plan on ordering a few.
