Skilhunt Defier X3 - first pictures
ichoderso
Germany
Hi, the new Defier X3 from Skilhunt arrived me today.
Skilhunt shiped this yesterday, so this was the fastest shipping time I ever seen😀
I will make some tests and measurements in the next time but today some of my first pictures I have made today
this is the description from the manufacturer:
DEFIER X3
LED: CREE XM-L T6
Copper dissipating heat design, excellent heat dispersion offer long time high mode lighting
Max output: 700lm
Operating Range: 3V~14V
Notice: DO NOT use 4 x RCR123A 3.7V Li-ion cells.DO NOT use 2pics extended tube or more!
Power: 3x CR123A 3.0V Lithium cells (Non Rechargeable) or Rechargeable Li-ion 3.7V cells either 3x RCR123A/16340,
With extra extended tube: 4 x CR123A 3.0V Lithium cells (Non Rechargeable)
2 x 3.7V Li-ion 18650 or 2 x 17670.
Dimensions:
Length: 193mm or 227mm (include extended tube)
Body Diameter: 25mm
Head Diameter: 45mm
Weight: 255g(exclude battery) / 8.99 oz(exclude battery)
Extended tube weight: 20g
Color: Black
Reflector: Smooth Reflector
Optional Reflector: Orange Reflector
Typical Output and Runtime:
Three brightness levels and Strobe mode
High 700lm (130min) –Medium 350lm(250min)- Low140lm (650min)--- Strobe (260min)
Accessories: Holster, Extended tube, Operator's manual, Two Spare O-rings, Spare Tailcap Rubber Boot, Peg ring,550 paracode lanyard, Silicone Grease
Optional Accessories: Filter, Weapon Mount and Remote pressure switch, X1's Tactical tail, 550 paracode handmade lanyard
Operation:
1. Battery installation: Twist the tail to loosen and remove the tail, then insert the battery with the positive end toward the head.
2. Flashlight turning on/off: For momentary light, gently press (no click) the tailcap push button switch.
For constant light, fully press (click) the tailcap pushbutton switch.
3. Output selecting
Side mode switch button to transferring mode, circulate as High—Medium—Low. Press side mode switch button (keep 2 seconds) to Strobe.
4. Intelligent momentary memory function: Remember last used setting & will come on at same level as when turn off
and now some of my first pictures:
Looks really good.
Should have some nice throw too. The copper is icing on the cake and it should let you know there is some there when you hold it.,
bigC
man, that copper head looks very nice. Thanks for all the pictures, any plans for beamshots or comparisons to other lights?
Hello Folks;
I am a newbie attracted to this addiction.For me, this will be an addiction.
Nice review
ichoderso. Have read a couple of your reviews. I appreciate you taking the time for our benefit. Thank you. This drew me in to purchase the Olight SR-90. Holy cow this thing is bright! My first real flashlight! I live in Las Vegas city, so have to be careful illuminating the sixth house down the street!
But, to backtrack a bit, what got me started down this road was an, OBTW-I have a four year old Fry's store credit to use. So, along with my original purchase, I used the balance of my store credit towards an INOVA T4 rechargeable. Found it is pleasantly bright. Hadn't checked out LED lights in a few years, and they've come a long way.
Which brings me here. Down this addictive road of LED flashlights. I am interested in purchasing one of these X3's. Could someone please point me in the correct direction to buy one? :help:
Thanks for your time and the valuable information,
Tony
hi griffs68dart and :welcome:
the light was bought directly from the manufacturer in a special promotion and is not yet available at the usual dealers, you'll have to wait until a dealer starts selling it.
Wow, excellent pictures. Thank a lot!
Looks very sturdy & well made light.
I'd appreciate if you show the beamshots.
That copper looks more like brass. Perhaps it's just the White balance of the photos. Are you certain that it is copper?
well, black anodisation would be best to maximize the heat given off by radiation, but it's certainly not black 😉
Thank you for the info. I contacted the manufacture. She referred me to an individual in the States. I am going to email him for a quote. Will post what I find out. :shrug:
Tony
Say, is that the tailcap that came with it? The tailcap for the X3 looks different in the catalog. That looks like switch for an X1.
