James3
- Joined
- Mar 6, 2013
- Messages
- 260
So I put a Dr. Jones RGBW driver with XML colour led into a skilhunt h02, turned out great, lots of pics below
Driver modes:
Colour cycle
cycles forward through the chromatic circle (red>yellow>green>cyan>blue>purple>red>...
White - ramping up and down
Simple modes and blinkies
red -- green -- blue -- EU yellow warning strobe -- EU blue emergency vehicle strobe -- US red/blue police strobe -- wild color strobe. T switches off.
Full RGBW mode
This mode lets you change every die's brightness individually, so you can mix every possible colour.
Lockout
Battery level indicator
This mode also has 2 sub-modes, one displays the voltage simply as a color: 4.5V-white, 4.0V-blue, 3.5V-green, 3.0V-red, intermediate colors for intermediate voltages. The other mode indicates the voltage by blinking; red for whole volts, green for tenths, blue for hundredths, e.g. 3*red, 6*green, 2*blue means 3.62V. [/COLOR]
All of the above modes have their own memory, they'll start with the settings used last time?
Measure cell capacity
This driver can measure the cell's capacity (in Ah) and stored energy (in Wh) with a load of 700mA down to 2.9V. Insert a full cell, activate this mode. It will then run for a few hours till the cell is drained and go into sleep mode. Press the button and it will tell the capacity and energy in blinks like the battery indicator above, i.e. a short white pre-blink to indicate capacity readout, 2*red, 5*green, 1*blue -> 2.51 Ah (= 2510 mAh), then a green pre-blink to indicate energy, then 8*red, 4*green, 7*blue -> 8.47 Wh. Can be repated by another tap. Exit this mode by changing the battery.
Measure internal resistance (including contact resistances
This mode allows to measure the internal resistance of the cell, but including the contact resistances. It will light up for ~10s, pause, and then show the resistance by some blinks in mOhm, e.g. 1*red, 7*green, 2*blue -> 172 mOhm. The measurement is repeated over and over, T to switch off.[/COLOR]
MG]
[/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
Driver modes:
Colour cycle
Full RGBW mode
Lockout
MG]
