LLMister
Hello y'all , I have recently bought a Sky Cannon SC180 600 but the bulb burned out and I need your expertise on figuring out what the replacement would be , since the company is out of business and there is not much on the web on this searchlight.
I found a light bulb that looks exactly the same as the broken one but it comes in a few variations and since it's quite expensive I better make sure to get the right one .
The is a USHIO SMH 600SC1 bulb that has the same base and looks but it either comes in 68 Volts / 600 Watt or 90 Volts / 800 Watt .
I posted photos of the igniter module to see if anyone of you would be able to point me in the right direction.
Thank you in advance in any case
