Sky Lumen Nguyen Flashlight Torture Tests Videos
Skylumen
Yep! My back yard... :)
I just talked to my military buddy and he said we can do another Driver Over with one of the MUCH heavier military vehicle! I cant say no to that! This mean we will HAVE TO destroy another production 7075 sample. The question is which serial to be be killed?!
But first may be I can send you the current 6061 sample to be shot at? Do you think you can help us make a video?
twistedraven
Time in Min until "too hot to hold": 4m30sec
Time in Min until peak temp reached: 5m20sec
Can circuitry handle heat nonstop? Yes
Max start up lumen: 3100
Test ending lumen: 2200
Alex1234
Bear Delaware
Time in Min until "too hot to hold":5 minutes
Time in Min until peak temp reached: 9 minutes
Can circuitry handle heat nonstop yes
Max start up lumen:3050
Test ending lumen:1950
Flash-O-Maniac
Time in Min until "too hot to hold": Never Happens
Time in Min until peak temp reached: 6 minutes
Max start up lumen: 3,150
Test ending lumen: 1,800
noboneshotdog
Time in Min until "too hot to hold": 4min
Time in Min until peak temp reached: 7min
Max start up lumen: 1500
Test ending lumen: 1000
thedodgedud
Time in Min until "too hot to hold" : 25sec
Time in Min until peak temp reached: 50sec
Max start up lumen:3900
Test ending lumen:1600
Patriot
Arizona
I can also shoot and record if help is needed. I have at least a dozen pistol calibers and a dozen rifle calibers and access to hundreds of others. Just my opinion but I don't think rifle calibers will be helpful or necessary. It would be fun to see .22, .380, .38spl, 9x19, .45, and then whatever it takes to make it stop working. I think one hit on the head with 10mm or .357 would cause enough deformation and perhaps shock to disable it.
Skylumen
Shots should be center mass where its strongest. If the light survive from the shock then its already too impressive. I personally don't think it can handle 9mm but I haven't handled 7075 either.
Jader
Time in Min until "too hot to hold" : 2min 50sec
Time in Min until peak temp reached: 4min
Max start up lumen:3800
Test ending lumen:2200
twistedraven
If it's 7075 hitting slightly off center where it curves away then I can see a 9mm bouncing off it.
Patriot
Arizona
That sounds wise and consistent and I'm guessing that's where the thickest part of the light is?
Based off all the mild steel plate of various gauges I've shot at over the years, I don't think 115gr 9mm @ 1125fps will cause deformation. A 115gr 9x21 or .38 Super @ 1450fps... probably a different story. Failure from shock though, I have no idea. I don't know what typically fails first from shock on a flashlight.
Patriot
Arizona
For sure. Bounce/sheer/deflect into a spray of fragments. Even square on I think the 9mm will lose most of its mass to fragments. It will be neat to see what Scout comes up with.
Patriot
Arizona
Time in Min until "too hot to hold": 5m30sec
Time in Min until peak temp reached: 7m30sec
Can circuitry handle heat nonstop? Easily
Max start up lumen: 3600
Test ending lumen: 2000
revilo951
Time in Min until "too hot to hold" : 4 mins
Time in Min until peak temp reached: 5 mins 20 secs
Max start up lumen: 4500
Test ending lumen: 2500
Skylumen
I killed ad on my torture and future videos. Should be better to watch in the future :)
Kozy
Hungary
Time in Min until "too hot to hold" : 1min 45sec
Time in Min until peak temp reached: 3 mins
Max start up lumen: 3800
Test ending lumen: 1350
Newlumen
United States
Time in Min until "too hot to hold": 15 minutes
Time in Min until peak temp reached: 10 minutes
Can circuitry handle heat nonstop? No
Max start up lumen: 5300
Skylumen
Glad to see you are back around. Miss yah!
