Odd occurrence today with the MC3K and DEX.....
Refreshing an INR 18650 3000mAh Samsung 30Q...but it got stuck on the first discharge cycle....
Program set to .7A discharge current
Cutoff voltage at 3.0v
For reasons I can't discover, the charger went to 0.0A discharge current when the battery was at 3.1v and never recovered.
That caused it to "hang" (because it could never reach 3.0v if there was zero discharge current)...and so it sat for an hour at 3.1v until I noticed....which is not good to leave batteries that far discharged for long so I was a bit disappointed with the charger. I'm not certain, but my guess would be that the charger failed to account for the rebound voltage after the discharge load was removed.
Here is the log entry where it went from 3.1v to 3.0v after about 4.5 hours....
00:16.277 / 3.00 / -0.7 / 2766 / 2.1 / 10.2 / 27.7 / 24 / 41.6
Here is the log entry where the discharge current dropped to zero........about 3 minutes and 45 seconds later.....
00:16.501 / 3.00 / 0.0 / 2809 / 1.3 / 10.3 / 27.7 / 24 / 39.8
Then the battery voltage rebounded back up to 3.1v.....only 36 seconds later...(probably because the discharge load was removed)
00:16.537 / 3.10 / 0.0 / 2809 / 0 / 10.3 / 27.6 / 24 / 38.5
And almost an hour later......still at 3.1v....and 0 current (stuck forever!)
00:19.711 / 3.10 / 0.0 / 2809 / 0 / 10.3 / 25.7 / 24 / 26
Here were the program parameters....
- Battery Type: LiIo
- Mode: Refresh
- Capacity:3000
- Charge Current: 1.0A
- Discharge Current: .7A
- Charge Cut Voltage: 4.2
- Discharge Cut Voltage: 3.0
- Charge Cut Current: 0.1
- Discharge Cut Current: 0.5
- Cut Temp: 45C
- Cut Time: OFF
The Temp never exceeded 42C for the system or 29C for the batteries
Anyone have any idea why it did this and how to avoid it?
Thanks
