In relation to temperature output all I'm able to find form the mc3000.xml file in reference to temperature output is
<unit>°C</unit> apparently a default output is in centigrade.
<name>system_temperature</name>
<symbol>Ts</symbol>
<unit>°C</unit>
<active>true</active>
<statistics min="true" max="true" avg="
I went into the properties editor and changed all the temperature units from "C" to "F" and the previous temperature unit (Centigrade) from the mc3000.xml file has been replaced by <unit>°F</unit> (Fahrenheit)
However, now DEX produces an error message upon gathering
" A serial communications to the device showing errors: ArrayIndexOutOfBoundsException - 8Disharge."
I did switch to a discharge and then float mode however the same error is being produced while trying to gather.
I think I'm going to reinstall Dex as something may have been messed up with it's configuration.
Then try again changing the temperature units to "F" Fahrenheit. Previously trying to edit the temp units resulted in some mixed "C" Centigrade and "F" Fahrenheit output.
This time I'll observe more closely and pay attention to any changes made to the mc3000.xlm file.
<symbol>Ts</symbol>
<unit>°C</unit>
