gdillainepub
- Joined
- Aug 25, 2015
- Messages
- 25
Thanks for sharing the details of your concerns. MH-C9000 comes with a limited 3-years warranty, i would test that out.
Yes both charger models have pitfalls and tbh i am not stoked with either one either ( ).
Erhm .. the mc3k iOS app hasn't been updated in a long time while there were many updates of the device firmware since. Clearly, the old iOS app still works (as i heard) but it will not 100.0% match the present firmware version ( that's my educated guess ). If you have specific questions re MC3000 (user manual, cycle history, eneloop, better than NC2500/C9000/etc?), i'll be glad to answer them in that thread, thx!
Hi kreisl,
Thanks for giving opinions on my thread : http://www.candlepowerforums.com/vb/showthread.php?407071-Seeking-advice-on-new-charger-purchase
Well, I do have a few questions about the NC3000. Unlike the NC2000 which you will need to choose a program (charge, refresh, etc.) , then you just leave the charger for the rest, until you wanna change of its charge termination parameters. But the MC3000 which I haven't seen the real product, the iphone app, it seems it complete works a different way --- you literally need to program every task, even for NiHM cells that has industrial standards how they should be handled.
So i tried to add a program, but some parameters confuses me. Following are the examples (all for NiHM) of the parameters I don't know what they are and their significance to guarantee a proper "handling" of a NiHM cell:
1. Charge: what are Cut Current, "Target Voltage", "Cut time", "Restart Voltage"
2. Refresh: seems to have the same parameters, but there is no "rest time" - the time the battery should be allowed to "rest" between charging/discharging.
3. Break-in: I'm amazed that it has the set of parameters as the Charge program -- because what "break-in" means is actually a procedure prescribed in an IEC standard (did some homework and I believe it should be IEC 61951-2) and labeled capacity is the only variable -- what's point to still provide so many variables, because if you don't do that the IEC way, it is not a "break-in" at all.
4. Cycles: there is a "Circle time (min)" -- i don't quite get that: you set how many cycles you wanna run and the sequence your prefer (like D->C->D or C-D-D, btw, providing options for the sequence is really sweet), and that's it -- what else time parameter would that be? And for the rest of the settings my questions are the same with Charge/discharge, and again, there isn't a "resting time" setting.
5. The last thing that puzzles me is that they have "eneloop" listed out from NiHM, but the parameters to set are the same as the generic NiHM settings. What's the point?
Well these are so far all my questions by only look into the iphone MC3000 app. But I did read somewhere in this post you said the MC3000 does provide "rest time" option somewhere (guess not from the app, at least not the version I have)
And yes! I would loooove to peak into the manual and see what is monster charger can do -- do you have it? anywhere i could download?
Since you could actually got your hands on the real thing and even the subsequent firmware updates , I guess you must have some inside sources you could poke around -- any word on when it will finally come to market? Oh hell, i wish i could have one of those right now like you do!
