Re: SkyRC — IFA 2014 / CES 2016 — MC3000 charger-analyzer The main functionality of DEX/MC3000 is (comprehension note:
manually = your hands dirty on the device):
- DEX-logging data to external screen (you need to start slots on the charger manually!) and DEX-saving data to PC-file format (OSD, CSV, BMP/PNG). We learned from Ravel and the DEX-maker that, in the end, you don't even need a PC/laptop for long-term logging: Raspi is a 2-4Watts PCB which could do the DEX-logging instead of your remote PC/laptop.
- DEX-backup of your manually entered 30 programs in visual PC-file format (TXT) or functional PC-file format (XML). The XML-file would be also suitable for direct sharing; just don't change the original file name, then overwrite the existing file with the shared one. The XML-file is not meant for public sharing, i am just saying that it could be used for it instead of sharing TXT-file or reposting the TXT-file contents on forums.
- DEX-restore of backed up programs from the XML-file. The restore is fugitive since the current settings in the slot are overwritten but not in the device memory. The 30 programs in the device memory remain untouched when you do a DEX-restore, similar to the workings of the bluetooth app. For example, you could run 4 programs sourced from your fliend's XML temporarily in the charger bay, none of which matches any of the 30 programs stored on the charger; basically making your charger host 34 different programs at that moment: 30 device programs plus 4 'slot programs'. When you stop a slot or play with the device keys lol, the DEX-restored program in the slot will be gone and the slot is ready to start the indicated program number.
The above explanation of DEX functionality answers your question: No it is not possible to
create a charging profile from scratch in DEX.
For building a library of profiles, a big TXT-file or summ ting, one would do the following:
- Create charging profiles manually on the device, up to 30 different ones at a time. Either by heart from scratch or by peeking at a small TXT-file/printout
- Send the 30 programs to DEX for a DEX-backup. DEX automatically creates that XML-file, the file name and location are fixed!
- In the DEX 'MC3000-Dialog' window use the <Clipboard> button and copy paste the programs in visual format to a single TXT-file. At the end of the day your TXT-file will contain 30 programs in visual format.
- Go to 1., and repeat the steps. Add as many different programs to the TXT-file as you want.
- Now you have a big library in form of 1 single big TXT-file. Feel free to share (file upload or content copy paste) or print out.
For illustration purposes lemme repost the animated
really awesome GIF demonstrating the 'MC3000-Dialog'. i am pretty proud of the file and i will never get tired of reposting it or its URL:
lol
