Thanks for posting this, as it might be significant.New firmware 1.21 is available. I noticed the following changes compared to v1.18:
- modified IR calculation (higher values than before; could be an interesting change as IR calculation was considered broken for firmwares released after v1.15)
If possible, could you try to quantify the change you observed in DCIR measurement after you did this update? Any rough estimate of the approximate magnitude of the change would likely be helpful in understanding this issue.
The info I've seen on the problem of concern is very limited, but below is the best example I've seen of a quote of a user-reported description of the problem which was introduced in the past FW update. As you can see, the error was not small, it was huge, with measured values dropping to ~20% of their previous, correct, same-cell measurements, rendering them effectively invalid.
Based on the info below, do you think the previously-introduced defect / bug has likely been resolved / corrected in this latest version, or perhaps just changed marginally, but that the measurement is still likely incorrect?
Thanks!
Users have encountered serious issues w/ 'internal resistance' measurements using later version(s), and I've heard nothing regarding resolution of that problem to date.
Here's one quote:
Just something I noticed after updating my MC3000 from v1.15 to v1.18:
the DC IR resistance reading becomes too low.
for instance, I had a high-drain 18650 battery that registers around 28-31mOhms back in firmware v1.15
but after updating the v1.18 firmware, the DC IR reading is just 6-7mOhms.
another button-top 14500 battery (button-top will usually have much added resistance),
in firmware v1.15, it was reading around 100-110mOhms
but in firmware v1.18, it was just reading around 20mOhms
since I had previously been jotting down the DC IR values of many of my batteries (using the v1.15 values), I decided to just flash back to the v1.15 firmware, which appeared to restore to the old DC IR values
