Here's a mod that someone requested. This one was a tough one since I wanted to make a "drop-in" module so the mod was not permanent (with the exception of the reflector) & could swapped to a new host if needed.
I used an Ultra Stinger's bulb base as the connector. The threaded hole is to aid in removal of the module. Screw in a screw & simply pull it out.
-SSC P7 CSXOI
-Modified Hotlips-D Heatsink
-Powered by 3000mah NiMh battery pack (may be upgraded to a custom 4500mah pack)
Thanks for looking. :wave:
Edit: Beamshots added
Beamshots compared to a Mag using the stock smooth reflector direct drive off 1 C li-ion. Both lights at tightest focus. The HP reflector performs far better than the stock smooth Mag reflector, tighter beam, more throw, & less artifacts since it's semi-fauceted. The HP reflector can be backed off a bit to almost eliminate the donut hole unlike the stock smooth Mag reflector which gives a lot of artifacts when doing the same.
Left: Stinger HP CSXOI, Right: Mag1C CSXOI
Same order, low exposure:
-SSC P7 CSXOI
