Small Portable Radio's?
aginthelaw
Well-known member
NJ, USA
I stopped eating them after my grandpa passed. He’s the only person to make it perfect. And my grandma was a chef!
mightysparrow
Well-known member
Palookaville, USA
Been a ham since 2015. I don't come here often, anymore, but I am another member who has learned a lot from the people posting in this thread. Cheers to all, and stay safe.
Gene
Well-known member
Dunsmuir, Ca.
Wish I could contribute more to this thread but with everything happening nowadays and my lack of knowledge of shortwave radios and such, I miss this thread that covered everything in between.
PhotoJim
Member
Regina, SK, CA
Anyone played with HanRongDa radios?
I picked up two, an HRD-104 which is simple AM/FM (anyone know how to change it into 10 kHz AM tuning mode? :) ) and an HRD-737, which is an interesting multiband radio that does HF and CB as well as wide VHF reception plus your normal AM/FM. As a ham, I thought the latter might make an interesting scanner-type of radio, though I can't get it to tune into standard 2m band frequencies very well (like our repeater frequencies). It needs a tuning granularity adjustment that I don't know how to do (or if it can be done).
Lebkuecher
Well-known member
Nashville TN
PhotoJim
Member
Regina, SK, CA
PhotoJim
Member
Regina, SK, CA
HRD104 (not HRD737, oops, wrote on wrong radio but I'll leave this) notes as promised:
It's not a bad little radio. As noted in the video, it's very thin and fits well in the hand.
On FM, I find it to be pretty decent. It has good stereo separation (with headphones of course). Sensitivity seems, at a minimum, competent. I can pick up stations here that are slightly weak, and with good quality (a couple of 100,000-watt stations from 70 km away, and a 10,000-watt station that is normally easy to receive but tends to be noisy). Alas, there is no more distant FM to receive here unless conditions are just right.
As for AM, all I can say is ... it's awfully deaf. I can receive local stations fine, as well as a 10 kW station from 70 km away. I also receive a 50 kW clear-channel station well from about 100 km, though I have to turn the radio just right, and the signal is noisy. (This is indoors, in a single-storey wood frame bungalow.) But otherwise... it hears nothing, even slightly more distant stations that I can normally pick up on all but the worst radios.
If anyone has this radio and can scan the instruction leaflet/page for me, that'd be great. Mine didn't come with one. I was able to figure out clock setting and memory programming/deleting/surfing, but the change from 9 to 10 kHz steps on AM would never have occurred to me if not for that video.
PhotoJim
Member
Regina, SK, CA
Oops, that's the HRD-104 I reviewed. :)
The HRD-737 is pretty similar, but of course has a lot more bands. It suffers from some of the same issues that the HRD-104 does on AM mode - it's pretty deaf. It definitely doesn't seem to hear much on the aircraft band, even though I can normally pick up the ATIS frequency from my city's airport pretty easily on radios with an aircraft band.
Tuning to VHF ham radio frequencies is awkward because you can't tune precisely to frequencies that ham users use (e.g. our main repeater is on 147.120 MHz but I can only tune to 147.125).
For the money, though, it's a nice little radio.
JACKN
Member
Hi all,
There are some new Tecsun radios that I have not seen discussed here:
- Tecsun PL-368 which is the tall, handheld version of PL-330 (same internal). It has ETM, numeric keyboard and BL-5C battery compared with its earlier siblings in the tall, handheld format (PL360, Pl365).
- Tecsun M301 and M303 - the features seems weird. Slim, good looking, mobile-phone sized FM radio with sealed lithium battery, hand loop antenna, dsp chip, speaker, bluetooth receiver, recording and mp3. Seems to be made more for listening outdoor on its supposedly above average earphone. Recording of bluetooth music (but not voice calls) is a bonus. There's a upcoming M302 using 16340 battery instead of internal sealed lithium battery.
Sorry, I can't post links yet. I don't own any of them and am not related to Tecsun in anyway. They are just more accessible and affordable to me in my region. I came across them because I have a Retekess PR12 (thanks to you people !) and would like to find its equivalence running on alkaline instead of sealed lithium battery. The sound on PR12 is good :) but the sealed battery on my unit is not holding up :( Is there's something like the PR12 but running on alkaline battery out there ?
Jack
5S8Zh5
Well-known member
U.S.A.
But since the PL-880 has a slightly better built-in speaker, it really can take advantage of FM radio audio fidelity when listening to music, for example. This is not to say that the PL-990 has crappy audio–far from the truth. Indeed, I was impressed with the audio when I first put the PL-990 on the air. You only notice the PL-880’s superior audio while doing side-by-side comparisons. Is it enough to sway my purchase decision? No, not really. For AM and shortwave–which is where I spend most of my time–the PL-990 audio is robust.
Using my PL-990 almost exclusively with a 32GB SDHC micro SD memory card and numerous CDs sneaker netted. Great sound - right up there with the PL-880 imho. To make it perfect, they should implement an text scroll (like the Sangean DT-800 FM RDS, without connecting online or on air) to ID the track currently playing.
Lebkuecher
Well-known member
Nashville TN
Jay Allen posted his review of the Sangean ATS-909X2
I have always been attracted to this series but could never pull the trigger due to the reputation of being deaf on the whip but apparently Sangean has made some improvements. At nearly $300.00 a copy the 909X2 is not cheap.
Review
mightysparrow
Well-known member
Palookaville, USA
The ATS-909X2 looks much improved over the earlier version. The issues I've seen mentioned in reviews of the new model relate to: low volume in SSB mode compared to other modes; frequency readings being off a bit (possible to correct somewhat with firmware updates?); lack of synch. detection feature (although some users find that ECSS can be an effective substitute); being unable to turn off the "fast-tune" feature, once turned on; and interference due to proximity to a wifi router.
The price reportedly came down a bit this week. I guess it's nearest competitor could be viewed as the Tecsun PL-990. I saw one review this past weekend that compared the two (can't remember where I saw it). He seemed to say each radio had its stronger points than the other.
