Smallest 18650-light
tobbi KLEIN
Unfortunately the Search has been disabled.
Which is the smallest flashlight running on one 18650?
Are there any tiny lights like the Olight T15 without a huge bezel?
Good question. I don't think it is the smallest but the Regalight has a great balance between size and brightness.
Moses
i got the regalight already by myself. yes, youre absolutely right ->it's an awesome light!
but i was wondering, if there is a light running on one 18650 which is not much bigger than the battery by itself.
For every battery-type there seems to be at least one light, which is almost as thin as the battery-cell itself but i haven't seen such a 18650-light yet.
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=4411
ssc p4 led
104mm long 22.5 diameter takes protected trustfire 18650 http://www.dealextreme.com/details.dx/sku.5790
afew pictures to comparing it to the SS C3
suprised noone else noticed it on KD i have 2 and another on the way, does get kind of warm but not to hot to handle.
http://www.kaidomain.com/WEBUI/ProductDetail.aspx?TranID=4575
have ordered this one to :)#
dx link for Aurora V6 Cree P4 LED Flashlight (18650/2*CR123A)
http://www.dealextreme.com/details.dx/sku.12346
Aurora C6 Cree P4 LED Flashlight (1*18650/2*CR123A)
http://www.dealextreme.com/details.dx/sku.12492
i really liked the look of that one but decided against it due to the strobe/sos modes, if it was a simple hi/low i have would get several.
I received that same light from KD yesterday. Minde is using a Cree led. It's very bright and very smal for a 18650 light. Like you mentioned, it does get hot very fast, dunno if that's good or bad. I did have to ad a solderblob to the positive contact in order for some of my bateries to work properly. I also noticed where the threads are, the material of the body is very thin. :duh2:
Try http://www.shiningbeam.com
L-mini 18650 has last mode used memory which works quite well.
Strobe/SOS won't get in your way.
For $30.00 you should try it - I think you'd like it - clean design & bright
The light is barely bigger than the 18650 battery- like mmmFlashlights said.
The seller is new on here - but so far - I give him A+
He's starting out with a bang - great service - discount - great incentives - prompt shipping and fast delivery in USA
He may turn out to be regarded as well as David with Fenix .... time will tell
L-Mini sure sounds great. Any reviews?
Wondering how bright and how much throw compared to the Fenix P2D and P3D. Anyone knows?
Thanks,
Mo
Little Mini by Lightbug/Shiningbeam: first impressions - Fallingwater
http://www.candlepowerforums.com/vb/showthread.php?t=197110
L-Mini 18650 Cree Q5 "Version 1" Black - Ernsanada
http://www.illuminationforums.com/IlluminationForums/showthread.php?t=280
Thanks,
Mo
L-mini bottom:
L-mini left, MTE P7 right:
You can unscrew the head of the L-mini slightly to widen the hotspot. (Or remove it completely for candle mode.)There are double O-rings, no glue.
L-mini left, Fenix L1P right.
