No such animal, nothing even close from surefire.
Best you could do is a 9P/D3/Z3/C3 with a 105 lumen bulb for 60 minutes or a M3 with a 125 lumen bulb for 60 minutes.
After that they all go to 20 minute runtimes or large turboheads or both. I personally have never liked the 20 minute runtimes....for LEO or Military when someone else is footing the battery bill it's probably fine. Or when you don't mind carrying 6 extra batteries on you with your flashlight. But to go through $4-12 (lord help you if you buy your batteries in a store or that would be $10-30+) in batteries every 20 minutes is too rich for me. The light is amazing though that's for sure.
The closest one, and it's a rechargeable would be a 9AN with 140 lumens, and 40 minutes of runtime with the stock battery but packs could be built cheaply enough to get a hour out of it.
It could be done though, a 200 lumen p91 bulb is about 15 watts. A person could take a MR11 12 volt 15 watt bulb, in a package that would be close to the size you'd like. A mr11 would fit in a 1.25 housing easy, and using say 4 123's you could run them for oh with a fudge factor for high drain say 70 minutes. Be like a M4 with a M3 head and the brighter bulb but a hour+ of runtime. In fact that would be just about perfect a M4 with a 200 lumen 12 volt bulb and a M3 sized head.
Niterider makes bike lights from MR11's that are 15 watts and run for 90 minutes with a battery pack bearly bigger than a deck of cards that wouldn't be that hard to put in a reasonable sized handle and run. Probably be pretty easy to convert a 2D maglite into one, but that's probably out of your size range.
