insanefred
- Joined
- Sep 30, 2008
- Messages
- 453
One thing that is kinda bothering me is that it's a little decentered. Does anyone know how you can fix it?
Otherwise, what are your impressions of the TK20? Thanks.
A couple of my Fenix lights have had the emitter clearly off centre but the beam is also clearly off centre too...Cree LED dies are sometimes not centered under the dome precisely. Fenix attempts to center the die, not the dome, in the center of the reflector.
Cree LED dies are sometimes not centered under the dome precisely. Fenix attempts to center the die, not the dome, in the center of the reflector. When you shine it on anything other than a white wall, any trace of either case disappears.
Personally I think this was spouted off by a fenix fanboy, repeated a couple of times and is now internet fact. Not a dig at you, marduke, but something I've seen happen on a couple of other forums as well- someone says something unprovable, someone else repeats it, and before you know it everyone on the forum know's it's a fact.
On the TK20, has anyone heard so far if there have been problems with it hurting NiMH cells through over discharge, like the stories about the L2Ds a while back?
Some said (on the L2D) it was due to running the batteries down too low, some said it was using turbo mode for too long.
I just wondered if anyone has seen similar incidents with the TK20.
BTW, does it actually run ok on alkaline cells?
