Sofirn C8Fvn - High Output Oslon Thrower
vinhnguyen54
vinhnguyen54
  • Factory Link Here
  • Good build quality
  • Great hefty heat sinking design
  • Oslon Flat Black version utilize solid aluminum reflector as additional heat sinking mass
  • ​3000mah 18650 + Single cell charger included
  • VNX2 UI
  • VT5A for max performance
Oslon Flat Black $123
Lumen: 1900
Intensity: 140Kcd
Throw: 748m
XPL HI 6500K $85
Lumen: 2500
Intensity: 60Kcd
Throw: 748m
$5 to add V54 Engraving
https://s33.postimg.cc/jhr9x57jj/DSC_6112.jpg
https://s33.postimg.cc/d426txknz/DSC_6114.jpg
https://s33.postimg.cc/5o2x85k3z/DSC_6118.jpg
https://s33.postimg.cc/tf2aq9zqn/DSC_6121.jpg
T
twistedraven
Re: Sofirn C8Fvn - Compact Power House
Isn't Sofirn releasing a 21700 version of their C8? That would be more enticing.
vinhnguyen54
vinhnguyen54
Everything is enticing to someone ;-) especially when everyone has boat loads of timeless 18650.
Newlumen
Newlumen
United States
This is great.. I don’t think 21700 will improve much in vn lights.. I like 18650... they are cheap and widely available..
T
twistedraven
Their lower voltage sag and higher capacity is always a plus for highly driven lights.
A
Agpp
I concur with that.
21700 makes light larger and heavier. But in case of C8F - not much. And it seems like a worthy upgrade.
vinhnguyen54
vinhnguyen54
Oslon Flat Black will be the only option for this light. Thanks!
vinhnguyen54
vinhnguyen54
3000mAh 18650 + Singel cell charger included
nfetterly
nfetterly
Supporter
Cincinnati area, but lots of travel
I've got a vn light with Olson in it on it's way. I'll make a decision after I see that one....
vinhnguyen54
vinhnguyen54
If I'm not mistaken you got the Goliath ...you going to be so in love with the Oslon.
B
b8llzblue
Really? Why is that? Did you try sd sst40 Or xpl hi and did not like the results? I was waiting and maybe wanting to purchase this with those emitters. A 3500 lumen 70kcd sounds interesting enough.
Triple oslon numbers are 1900 lumens and 140kcd....I think that’s very similar to a xpl hi or sd sst40 on a regular single emitter c8.
vinhnguyen54
vinhnguyen54
I thought hard around this....May be I will add more LED options...
LessDark
LessDark
Norway
Looks like a nice light, do you have a estimate for how long it can run at 1900lm before it's too hot?
nfetterly
nfetterly
Supporter
Yes I did, as of a couple of hours ago it arrived locally (USPS regional center), I had it shipped to work so I may not get it for a while if I travel next week.
MAD777
MAD777
White Mountains, NH, USA
I'm keeping my eye on this one!
Wonder what different LED's specs are. Probably more lumens, less lux.
With Oslon, the lumen/lux specs are equal to the larger L30vn. Would love to see side by side beamshots to compare hot spot size!
IlluminationDomination
NW PA.
I have one on the way. Got it on the 2018 light sale.:thumbsup:
vinhnguyen54
vinhnguyen54
Excellent beam and tint
XPL HI 6500K $85
Lumen: 2500
Intensity: 60Kcd
Throw: 748m
Excellent deal as cell and charger is included
B
b8llzblue
XPL HI 6500K $85
Lumen: 2500
Intensity: 60Kcd
Throw: 748m
Is this with stock driver?
if so, can vnx driver be an option to get closer to 3500 lumens?2500 lumens sounds more like dedomed xpg2 numbers
vinhnguyen54
vinhnguyen54
VNX2 ;-)
LUmen numbers sound about right compare to others XPL HI triple though.
Newlumen
Newlumen
United States
Triple sst40 dome on might get close to 3500 lumen.
Similar threads
vinhnguyen54
Replies
611
Views
114K
brighterthanthesun
B
vinhnguyen54
Replies
136
Views
29K
OnlyownEnergizer250lumen
O
vinhnguyen54
Replies
61
Views
14K
AmericanDissent
AmericanDissent
vinhnguyen54
Replies
64
Views
17K
Gigaslux
Gigaslux
