Solarforce Forward Clickies and GITD Covers?
offroad
Planning to update my L2M tail caps with forward clickies and glow in the dark covers.
Looks like the cheapest method is described in this thread by old4570 and the switches are on KD (link in above thread)
What is the proper size for GITD covers, and is there a KD link or sku?
The L2 and L2M tailcaps use 14mm covers.
The L2-S6 forward clickie also uses 14mm covers.
I got green GITD covers from DX (sku 5714).
The L2P tailcap uses 16mm covers (got those from Shiningbeam).
Just got my first Solarforce L2 Cree R2 5 mode with memory in the mail today. When pushing in the button to turn it on, it is on one mode and when I let off on the button, it's in another mode. Turning it off it does the same thing. Is this normal for this light? If this is normal this is a horrible design, otherwise it's a great light.
Are you fully pressing until it clicks? It should turn on to the last mode you had it on, when you fully click the tail cap. If you click again (or half press) within a second or so it should switch modes. If you wait more than a few seconds the next full press (click) will turn it off. Sounds like your tail cap switch is not working correctly, contact your seller for a replacement.
Thanks for the link, but yes I had seen it.
