Solarforce L2 help please
Creecher
UK
I'm buying the stubby single CR123 Solarforce L2. Can I fit a battery tube and extra cell to it, or do I need a different emitter. I'm also buying a UV emitter. I've just made the order so need to know I've bought the right bits.
You need to see which LED module is in it. I while back, I contacted some of the Ebay sellers that carry the light you are talking about. I asked which module it had. Some had the 3.7-4.2v module and others had the module that if I remember right, accepts up to around 12 volts.
Get this one:
[FONT=Arial, Helvetica, sans-serif]Solarforce L2GF-R2M-18650[/FONT]
[FONT=Arial, Helvetica, sans-serif]L2 flat head assembly
Uses a Cree R2 LED 5 mode (300, 150, 75 lumens, strobe, SOS) reflector
Uses both primary lithium 2XCR123A or 2X16340 OR 1X18650 (included) rechargeable li-ion batteries
Up to 300 lumens of current regulated output (LED module)
Input voltage (LED module): 3.7V-8.4V
Aluminum alloy construction
Tail clicky switch
104 grams (without batteries)
Length x diameter (head and battery tube): 146mm x 32mm x 25mm
[/FONT]
Then get a stubby body (L2-B16G) for when you want to use a single CR123.
Get this one:
[FONT=Arial, Helvetica, sans-serif]L2 flat head assembly [/FONT]
[FONT=Arial, Helvetica, sans-serif]Uses a Cree R2 LED 5 mode (300, 150, 75 lumens, strobe, SOS) reflector [/FONT]
[FONT=Arial, Helvetica, sans-serif]Uses both primary lithium 2XCR123A or 2X16340 OR 1X18650 (included) rechargeable li-ion batteries [/FONT]
[FONT=Arial, Helvetica, sans-serif]Up to 300 lumens of current regulated output (LED module) [/FONT]
[FONT=Arial, Helvetica, sans-serif]Input voltage (LED module): 3.7V-8.4V [/FONT]
[FONT=Arial, Helvetica, sans-serif]Aluminum alloy construction [/FONT]
[FONT=Arial, Helvetica, sans-serif]Tail clicky switch [/FONT]
[FONT=Arial, Helvetica, sans-serif]104 grams (without batteries) [/FONT]
[FONT=Arial, Helvetica, sans-serif]Length x diameter (head and battery tube): 146mm x 32mm x 25mm [/FONT]
I like your way of thinking. Is there an emitter they, or I could put it the stubby that would work ok, or would it run really dim on one cell. They do a couple of lights that take 3-18v, but all the short 'M's run 3-4.2v.
I'm new to lego so I'm pretty clueless.
Pick any of the ones that will do 3-18V and if it is a long body version, then get a spare short body for when you want to use a single CR123. That is basically the rationale for what I am was trying to recommend.
Ok, I sent an email asking to change the order. Last question. If I run it with one cell, will it be half as bright as two, or just reduced runtime? And if I ran it with more cells (3 or 4) would it be brighter?
Thanks for your help.
No you will just get shorter run time ...
3.7-4.2v 5 mode
3-8.4v 5 mode
3-12v single mode [ Brightness may be affected with this one ]
If your going to swap n change Id recommend the first two pills ...
Either run single CR123A or single 18650 with the 4.2v
Or run single CR123A , 2 x CR123A or 18650 or 2 x 18650 with the 3-8.4v
3.7-4.2v 5 mode
3-8.4v 5 mode
Small clarification. Solarforce says there is 3,7-8,4V drop-in, not 3-8,4V.
Yeah , It varies .. The picture I saw of one said 3 to 8.4 ...
Just depends .. Ive seen so many different Pills offered ...
But ill stick to 3-8.4 as they wont run on Primaries , but will run on batts over 3volt ..
Geez , there are so many Pills offered , its just the 3 I mentioned , but I think there are variations .. So ??? There is the Blue / Purple / Red labels , and then the ones that just say Bright R2 , and then differing output levels .
When I got my first L2 , it was 3 to 8.4 , now as you said it seems to be 3.7 to 8.4 .. :ohgeez:
+ It might depend on the components they can get there hands on ??
Either way , I have 5 L2's ATM , that will do for now ...
But if they bring out a 4 mode L2 :ohgeez:, then it will be a new ball game .
+ R4 pills :broke:
:eek:
