Very slow delivery, but otherwise seems reliable.How is KD's customer service?
Norm
Help Support Candle Power Flashlight Forum
The lens will fit if you file the back of the crenulated bezel and or use a thinner O ring than the original.I put one of these UCL lenses in all my L2's (10 in all) save 3. One is the special all stainless one, and it seems that this light does not have a standard L2 lens. It is quite a bit thinner than stock and the 1.85 thick UCL lens is almost a third thicker. The shiny crenellated bezel will not screw down fully, so I had to forgo a UCL in that one. Its a showpiece anyway.
My other 2 holdouts are a trickier problem These two have the stainless strike bezel ring. Unlike the aluminum ones which unscrewed easily, and the flat stainless rings, for which my little tool unscrewed easily, the SS strike bezels are both frozen fast as if epoxied in. Has anyone had any success in unscrewing these bezels without doing damage? Chucking it in a vice and having at it with a pipe wrench are clearly not viable options!
I put in an order for a lens as well from KD. Seems like a cheap way to get some more output even if not that noticeable plus I have a backup lens.
How is KD's customer service? I sent an email to them and have yet to hear back from them and am worried they are going to send my order to the wrong address.
To remove your bezel try an old piece of carpet, with just the head in your hands try pushing the bezel into the pile hard and give it a sharp twist.
Norm
I've just ordered 5 of the KD lenses to try.
I've installed a couple of the 28.8 lenses from FlashlightLens.com. I had to grind them down to 28. Used a diamond file on one and a band sander on the other.
I'll have to compare them to the KD lenses when they arrive.
Hi Mike I have the same light with the KD lens installed, I'm using a red O ring (silicone I think) and the plastic ring (I like the look of the red O ring), I removed about .3mm from the back of the bezel, there is enough there to remove .5mm and you will be able to use the original black ring. The lens was centered and doesn't touch the edges at all. Also took the sharp edges off the bezel.Norm, the L2 bezel ring does not have an o-ring. It has a rubber retainer ring that the lens sits in. It looks like a bottle cap without a center. The glass sits in it and the rubber wraps around the side walls. The bottom of the rubber is needed to cushion the glass because it sits on a metal rim and then a fiber washer goes over it and clamps the lens and retainer down as you tighten the bezel ring. With this setup, the lens thickness is a critical factor and it means that no UCL is available that is thin enough. I don't mind though. As I said, this is only on the one-off special all stainless serial numbered edition I have. The standard L2's have a thicker lens, about equal to the 1.85mm thick UCL thickness.
I guess I'm asking where to purchase the Solarforce L2- 5 mode at the best price ( non-Ebay ). Links appreciated.
Great site and I will continue to follow this thread. Thanks in advance.- Bill
I'm new to the forums and want to purchase my first "tactical" flashight and am intrested in the Solarforce L2 impressions (Cree R2 5-mode) . ng visited the Solarfore store site I am confused as to which light is the Solarforce L2 with 5 mode. The closest I find is their Ultrafire 503B-R2M, after seeing a review earlier in this thread these did not have as" crisp threads" ect.
Try wiping it with alcohol then use the bottom of your mouse pad ( flat rubber sheet ) to grip with. They used to sell flat rubber sheets like clothes to remove jar lids.... I use these to remove stuck filters on camera lenes. Hope this helps.Same problem here, tried carpet idea with no luck. Placing it in a vice then twisting with channel lock or vice grip pliers may be the only way to get it to budge. But then it would be so mutilated there would be no point, might be easier just to buy a new SF head.
