radiopej
I've just received the Solarforce Z1 in the mail. It's a gift for a friend, but I figured I'd give it a look-over and review beforehand.
Solarforce's specifications (direct from site):
Premium CREE XP-G2 R5 LED
T6063 grade aluminum alloy body in extremely durable Mil-spec type III hard-anodized finish
Orange-peel-textured aluminium alloy reflector
Strengthened ultra-clear glass lens with two-surface anti-reflective coating
Stands upside down stably
Input voltage: 1.5 – 3V
Battery type: CR123A x 1
Reversed polarity protection
Water-proof (IPX-8 standard)
Length x diameter (head / body): 77.5 x 20.5 / 21mm
Weight: 37g
Output
Solarforce gives conflicting information about the max output, either 320 or 240 lumens. I can only assume this is dependent on the battery used (CR123 vs RCR123)
High (240 L): 40 min
Medium (115 L): 80 min
Low (35 L): 6 hr
Moon (7 L): 50 hr
Here are some outdoor beamshots. At 7 lumens, the moonlight isn't really moonlight - it's probably too bright for illumination while rummaging through your bag in the cinema. It's not bad for use as a general low-low though.
Note: While the site says the voltage goes up to 3V, the body of the torch clearly says up to 4.2 V. I popped in an RCR123 and it seemed fine, though it wasn't a freshly charged one.
Physical
It looks good to me. Nice and small, similar in size and weight to my EagleTac D25C Clicky. It's got a removable clip that looks like it can be taken off and clipped back on in reverse. A lot of you guys don't like clips that come off, but it seemed sturdy enough. A good, hard yank can probably take it off . It tailstands easily and the tailswitch is easy to press – this may be an issue in a pocket, but seems okay to me due to it being a bit recessed. Since it's a forward clicky, you get momentary use as well. The tiny bit between the reflector and bezel is a glow-in-the-dark ring. Pretty fun.
The die is nicely centered and the reflector is a nice light orange-peel.
Olight i3S, EagleTac D25C Clicky, Solarforce Z1
UI
A real winner for simplicity. 4 modes, as given above. Always starts on high, no mode memory. Each time you hit the tailcap, it progresses to a lower brightness before starting the cycle again. I love it as I won't accidentally strobe myself.
Beam
A nice mix of flood and throw, with a nice cool white without artifacts. Still, the center spot is fairly tight. I prefer neutral white usually, though the XP-G2 series have one of the nicest cool whites I've seen. As with most cool white lights, grass looks a bit pale. The wall shot is from about 50 cm away on high, the wall is actually yellow.
Overall
Overall, I love this light. I got it for USD $16 plus $2 for shipping, but even at a higher price it would be impressive. They also have the Z2 which runs from a single AA battery. Compact size, straightforward interface. I'm considering buying a handful of these to scatter around. It's not for tint fiends, but it's definitely got a place as a cheap light that's powerful, compact and good-looking. I don't know how durable or reliable it will be in the long run, but it's at a price point where you can afford to find out.
Weight: 37g
Output
Low (35 L): 6 hr
Moon (7 L): 50 hr
Physical
UI
Beam
Overall
