Sold/Expired SOLD: Lot of 5 lights for 1 price. old school mostly
mcbrat
mcbrat
Supporter
Iowa
$50 - SOLD for the lot... resurrected/modified/hacked together....
1. LumaPower Lumacraft D Mini. awesome little thrower. uses CR123 for sure. don't know much about this one. 2 level. full click for low. second full click for high. comes with both spare orange peel reflector, switch, boot, orings.
I just put an original sytle LED back into this one. I really like the UI.
2. Fenix . Just made up some 5mm LEDs for this, and needs a 10440 to run.
have spare LEDs as shown. one with blue marker around it is UV I believe.
3. Zebralight H30. first gen I believe. LED was just flashing when I got it. found a loose wire. but still has UI issues, and missing a screw for hold down ring. basically is just a single mode light. CR123 for sure. maybe 16340. don't know.
4. F & L J1 needs 15270 battery. engine was completely missing.was able to take some other pill parts (friction fit), and cobble in a Reylight Pineapple 4 level driver with the I think the stock reflector. I believe XP-G led. not correct for reflector, so has plenty of beam artifacts. The Reylight driver supports both Primary and LiIon batteries.
and maybe my favorite of this bunch
5. FourSevens Mini Mule. XP-G Led. started with a gutted brand new Mini ML-X, found a compatible screw in driver shell. Added Reylight Pineapple Driver (see above for info)
added 3 o-rings in the head to provide spacing for the LED/driver.
M
mattw
Re: FS: Lot of 5 lights for 1 price. old school mostly
If they get split up... I am interested in the lumacraft!
Chauncey Gardiner
Chauncey Gardiner
Pacific N.W.
Please describe the beam of the FourSevens mule. :) I'm definitely interested in it if you end up splitting.
~ Chance
mcbrat
mcbrat
Supporter
Iowa
~ Chance
package is now SPF, but for the record, from about 3 feet from the wall you get about a 6 foot diameter circle of light due to how deep set the LED is.
Chauncey Gardiner
Chauncey Gardiner
Pacific N.W.
Thank you. :) I'm going to repost one of the pictures of it in the 4 & FourSevens picture thread. :thumbsup:
~ CG
