spc
This is D maglite switch has had
-original bulb tower cut down
-momentary mod (internal gears shaved, all contacts separately wired)
-wired with a D2FLEX driver (from taskled) using mil-spec teflon wire
Basicly a drop in switch if you want modes on your direct drive P7 maglite. This driver is not a buck or boost, so if you solder it up to a p7, your battery combo has to be the right voltage match for the emitter.
SOLD (conus)
SOLD (conus)
