In excellent working condition. No scratches or dents that I can see. There is some dust. No box or batteries. Just the light. PRICE: $45 + $7 shipping to CONUS
Featuring the latest CREE XHP50 LED, Nitecore EC4S more than doubled the brightness of its predecessor EC4.
It emits remarkable 2150 lumens that provides over 300 yards visibility. It's convenient mode switch allows you to toggle through the light's five different levels of brightness or call upon SOS, beacon, or strobe. The new uni-body die-casting manufacturing process improves the heat dissipation, waterproof, durability while reduces its weight. As a result, the light excels at extreme, harsh environment for industrial, hunting and outdoor sports.
[*=left]Beam Distance: 306 yards / 280 meters
[*=left]Beam Intensity: 19600 cd
[*=left]Battery type supported: 2 x 18650 or 4 x CR123
[*=left]Dimension:
Body: 5.91 in (150 mm)
Head Size: 1.57 in (40 mm)
[*=left]Weight:
6.03 oz (171 g) (Without Battery)
[*=left]Waterproof: IPX-8 (2 meters submersible)
Features:
[*=left]Advanced Die-cast uni-body construction - improves the heat dissipation, waterproof and durability
[*=left]Excellent heat dissipation -keep light on for long hours at high output
[*=left]Unprecedented ease of use - dual mode and on/off switch design
[*=left]Extreme durability - 200% the strength of flashlights that have three separate parts
[*=left]Suitable for Industrial use - Abrasion resistant, corrosion resistant, chemical resistant
[*=left]Built-in battery power indicator shows remaining battery power
[*=left]Direct access to turbo/ultra-low outputs
[*=left]Impact resistant to 1.5 meters
[*=left]Tail stand capability
[*=left]A micro-textured reflector offers wide angle lighting
[*=left]Solid lightweight aero-grade aluminum alloy construction
[*=left]Thumbscrew lock on tail cap doubles as a tripod connector
[*=left]Reverse polarity protection prevents damage from incorrectly installed batteries
[*=left]Stainless steel retaining ring protects core components from damage
[*=left]Toughened ultra clear mineral glass with anti-reflective coating
[*=left]Dimples on side for long-time no-slip gripping comfort
Contents in Package: Nitecore EC4S flashlight,holster, lanyard
