Tain
- Joined
- Dec 14, 2011
- Messages
- 373
2nd Run, SOLD OUT
2012-Oct-31st update
1. Regarding the 0.9V issue. I will make changes to the driver. The 0.9V protection will be remove, the light will turn off even the battery voltage is below 0.9V.
2. Since I need to re-work on the driver, I am going to switch the mode sequence to low first, and high next.
3. I am going to leave high mode @ 200am (60lumen), and please let me know your preferred output( lumen) for low mode. I will pick the most voted output level for the low mode.
4. Re-building the driver will take a few weeks, I can assure you that the delivery time will not be in the end of Nov. If you do not want to wait, please email to "Piccolo.Ti(at)gmail(dot)com". I will remove you from the reservation list.
5. For the original version owners, I will contact you individually when I have the new driver built.
Hi guys,
I am making another 50 units for the 2nd(final) run. I will try my best to finish the lights by the end of Nov, so you can receive the Piccolos before Christmas. However, there is no guarantee the lights will be completed by Nov.
To reserve your spot on the 2nd run, please email to "piccolo.ti (at) gmail.com" with your CPF handle, quantity, tritium color choice, and glow color choice. Any of the 4 articles missing, the reservation is considered invalid. I need this information to order the tritium vials in advance. Please do not send your payments yet, I will collect payments when the lights are ready to ship.
1st Run SOLD OUT
Hi guys,
I made 50 units of Piccolo Ti. 35 units are pre-ordered, and 15 units are available.
Piccolo Ti
- Ti-6AL-4V Titanium Shell.
- Beefy brass light engine for maximum heatsink
- Knurling on the head and body.
- Split ring hole
- One 2x12mm tritium slot in the tail.
- Tail-stand-able
- Tighten off, Loose on
- Dual stage output - 200ma, 20ma (high first, low next)
- 13.5mm x 67mm
- 0.9V~1.8V (light will not turn off if the voltage is below 0.9V)
- Alkaline, Ni-MH, primary AAA lithium
- No 10440 Li-ion
- Emitter Nichia 219 92CRI
- TIR Optic
- Glow in the dark. (Green, Aqua, Blue)
Operation
1. Install an AAA size battery into the body tube, with ( + ) positive end toward the tail, and ( - ) negative end toward the led.
2. Fully tighten off.
3. Loose to turn on high.
4. Loose further to turn on low.
Price
- Base $140
- 2x12mm tritium vial: $15
- Registered airmail: $5
Paypal: SOLD OUT
Please include your trit color and GITD color choices in the note.
Hi guys,
1st Run SOLD OUT
Hi guys,
Piccolo Ti
- Split ring hole
- Tail-stand-able
- 13.5mm x 67mm
- No 10440 Li-ion
- TIR Optic
Operation
Price
- Base $140
Paypal: SOLD OUT
