SCEMan
Solarforce L2 Silver with Nichia 219B and 18650 extension
Mountain Electronics P60 Module:
• Nichia 219B: Neutral White (~4500K). Approx 500 LED lumens. 92+ CRI OP (Orange Peel) reflector
• 3 Mode: 2% -- 25% -- 100%
• Noctigon direct-thermal-path MCPCB / Brass pill / Aluminum reflector
• Memory (needs to be on in mode for about 2.5 seconds before mode is memorized)
• Qlite driver: 6x7135 Chips ~2.2A to the LED
• Reverse polarity protection
• For 1 x 4.2v/4.35v lithium-ion battery (can NOT be run with two cells in series.)
• EXTENSION CANNOT BE USED WITH THIS P60 MODULE!!!
Drop-in is aluminum strip wrapped for heat transfer
Forward Clicky
Tailcap modified to accept large 16mm buttons
Pocket clip has lanyard hole removed and edges smoothed for improved feel.
Stainless bezel ring
NOTE: The 18650 extension is fully functional but does not match the color of the head/body/tailcap.
Works perfectly with beautiful tint.
$40 shipped CONUS only
Forward Clicky
