Sold/Expired SOLD Surefire Hell Fighter
Status
Not open for further replies.
SoCal
SOLD*****WTS Surefire Hell Fighter High Intensity Spotlight/Searchlight. Includes Pelican case, cables with 12 volt connecter, IR lens cover and mount for M2 Machine gun. This light is INTENSE although I'm sure nobody in CPF needs to be told that! Additional Hell Fighter head (working) with IR lens cover is also available. Asking $650 for light with case, cables, mount and IR filter. Shipping at actual cost. Second Hell Fighter head sold separately. Thanks for looking.
Description from SUREFIRE Catalog: Hell Fighter High Intensity Discharge (HID) Light
The HellFighter™ packs power and versatility into a tough, compact package that weighs only 10 pounds and measures a mere eight inches in length. It features a shock-isolated ultra high-output HID lamp assembly that generates a blinding 3,000-lumen beam with enough reach to illuminate targets hundreds of yards away and enough surround beam to make it perfect for patrol or search-and-rescue operations.
Designed to mount on a .50 caliber machine gun-to either the gun's sleeve or shield-the adaptable HellFighter can also be mounted on an M44 Minigun, a vehicle, or be detached and used as a handheld searchlight (all mounting systems sold separately). Its rugged high intensity discharge lamp (HID lamps have no filament to break or burn out) is powered by one or two military 5590 batteries or from a 12-volt auto battery. The HellFighter quickly connects to either with a 10-foot cable (included) that features both military 5590 connectors and an auto accessory (cigarette lighter) plug. Activating the HellFighter is achieved via a rear-mounted pushbutton switch or a remote cable switch (not included) featuring both momentary- and constant-on.
Built to withstand intense recoil and combat conditions, the HellFighter's water-resistant body is constructed from aerospace-aluminum hard-anodized with a Mil-Spec Type III finish. A 5mm multi-coated Pyrex® window protects its lamp assembly, and a filter on a pivoting mount swings over the window for additional protection or specialized lighting.
Max Output: 3,000 lumens
Runtime: Auto battery: continuous
Two 5590 military batteries: 8 hrs
Length: 8.0 inches
Weight: 10 pounds
Bezel Diameter: 4.1 inches
Filter Options: Infrared, amber, opaque (one included)
Mounting Systems: (sold separately)
.50 cal sleeve mount
.50 cal shield mount
Minigun mount
Vehicle mount
Switching: Two momentary- and constant-on:
One in light body
One in spade grip (sold separately)
Cable Length: 10 feet (sold separately)
Please Note: This item cannot exported from the USA. DO NOT ORDER this item if you are outside of the USA. The only exception allowed is for APO/FPO and similar addresses with a US zipcode.
SPECIFICATIONS
TurboHighMediumLowMoonlight
Lumens:30003000---
Runtime (Hours):-8---
Output Modes:Dual Brightness Levels
Compatible Batteries:Battery Pack
Batteries Included:Yes
Included Accessories:Batteries
Flashlight Usage:Search, Tactical
LED:Nichia n/a n/a
Brand:SureFire
Warranty:Battery Junction 30-Day Warranty, SureFire Lifetime Warranty
Return Policy:Battery Junction Return Policy
Primary Material:Anodized Aluminum
Product Weight:104oz
Product Dimensions:11" (L) x 4.1" (Head Diameter)
Country of Origin:US
usdiver
Well-known member
In the Sticks
Re: WTS Surefire Hell Fighter
DAAAAM! [emoji14]if only I had the money I ve been wanting one of these!
Status
