mdarby
I am relatively new to soldering, and completely new to soldering batteries. I want to create an 8-cell pack of AAAs. I planned to solder the four pairs together, make 3 positive terminal to negative terminal connections, then solder the positive/negative terminals of the new pack to the plates from a C-battery, which is about the same size as 4-AAAs. Does this make any sense?
I found the following instructions using Google:
http://www.silentflyer.org/articles/soldering_batteries.html
Is this the best method for soldering batteries end to end? I don't have the hammerhead tip. Is there a way to go without that part?
Thanks.
Thanks.
