zespectre
In all my years of tinkering I've pretty much always used either your common 40 watt "pencil" soldering iron, or one of the more powerful "pistol grip" types depending on the application.
Just recently another hobbyist looked at me and told me I was crazy and I needed to invest in an actual controlled heat soldering station.
I kind of ignored him until I killed my last tip for my current iron and then decided to do some shopping and after many reviews I settled on an X-Tronic station
(note, not plugging X-Tronic specifically, it's just the one I chose)
GREAT HOPPING THOMAS EDISON! Why was I ever so stubborn before??? This thing is just the cats pajamas!
Also, I still use a damp sponge for tip maintenance, but I also splurged and bought one of these "tip cleaners" as well.
VERY nice! Another item I wish I hadn't waited so long to purchase for this use.
I guess what I'm saying is if you solder even semi-frequently you should do yourself a favor and get a real, temperature controlled, soldering station.
- Setting your iron to a consistent temp and knowing it will stay there (or almost instantly return there) while you are soldering is AWESOME.
- A higher grade soldering station like this comes up to temperature within a minute tops [EDIT/CORRECTION: 16 sec from cold to operating temp], not 4-5min like my other stuff did.
- The variety and quality of tips is waaaaay better
- Knowing that it will auto-sleep if you don't use it for a while is very good (no more accidentally leaving your iron plugged in and on overnight)
