andrewwynn
Well.. i made a trade to make a sandwich for a CNC123 for a bud on cpf... he sent me a VIP driver to assemble with a TWOJ emitter.. but i needed to make some heatsinks for his and other CNC123 lights..
Well i've made one already using some PCB material but the copper on those is mighty thing and what i really wanted was some solid copper i could cut using the same method... he said he happened so have some from his days as a jeweler... so i teased him that.. well silver is actually more conductive (thermally and electrically) than copper... so he fired back.. 'well i have some sterling silver laying around too'..
The title of the post ruins the punch line of course.. but the summary is.. after some tedium and a LOT of oil.. i was able to use my wood plug-cutter to cut some solid sterling silver heat sinks.. i'll post some pictures soon as i can they are very cool. They look like a dime before it is struck.. but a little smaller diameter.. in any event.. my guess is they are the only two in the world.. who'd be nuts enough to use actual silver to make their luxeon heatsink, huh?
the post-tedium and lot of oil.. was that the first try was abysmal .... the cutter just kept grabbing the material and moving it around.. it was like a fancy silver spyrograph.
I tried again with copper.. and it wasn't much easier but being softer metal it did work... but that was last night..
today i decided to try clamping the material harder.. and starting slower.. and using constant oil bath.. and sure enough it worked.. in a matter of 5 minutes i had a perfect little slug of silver.. in-fact in 10 minutes i had two silver slugs and one more copper one... this time the silver actually cut easier than the copper.
Well.. back to the saltmine.. i'll post pics when i get a chance.
ok: pictures:
click on the picture for a couple more.
the center disc is a copper PCB.. the far two discs are copper heat sinks..
when taking the time, the plug cutter works fabulously well for cutting perfect circles.. it creates a bit of flashing on the back side of the hole as it cuts that needs to be sanded off but quick few sec. with a dremel and it's a perfect circle.
-awr
ok: pictures:
-awr
