I have almost completed my first mod of a maglite solitaire. Before I hook it up I wanted to ask a few questions so I don't ruin the LED bulb or anything else for that matter.
I am using a radio shack 2600 mcd blue led bulb
My questions are:
(1) is it necessary to use a resistor with a 12v a23 battery? would it run better or safe with the resistor?
(2) how is the solitaire light turned off? I know by screwing in the head it turns off but what exactly is causing the light to turn off ?
(3) some mods call for the use of a washer to fit over the LED to help the light turn off better, so the washer needs to push on the LED itself? or push on the black housing the LED plugs into? this related to the second question I guess.
I found an old pen that has a clear casing that is the exact diameter of a AAA battery, so I will use that to make the spacer. Ive read in a lot of mods that no resistor is needed with that battery, but some mods say the flashlight will run hot if no resistor is used.
Thanks in advance for the help
My questions are:
