Question,
Specifically, did you install Network drivers from the Dell website? There should have been at least two of them. One for the Ethernet card and one for the Wireless.
Another important one would have been the Chipset drivers.
To answer your question to/from Egsise...
Open a DOS window (type CMD in the Run box)
...in the DOS window type..
ipconfig /all
See what it tells you.
Same way, in a DOS window..
type..
ping 127.0.0.1
If successful, it means your network card, drivers, etc are working properly.
I'll hand it back to Egsise now...
Ok, here is the list of drivers I was given. I got all of the ones that said recomended, urgent, and several of the ones that said optional.
http://support.dell.com/support/dow...nspironI6400/E1505&os=WW1&osl=en&catid=&impid=
Here is what it said when I did the ipconfig
Host name..........: Danny
Primary Dns suffix......:
Node type.......: Broadcast
Ip routing enabled......: No
Wins Proxy Enabled.......: No
Ethernet adapter Local Area Connection:
Media State............: Media disconnected
Description..............: Broadcom 440x 10/100 integrated controller
Physical Address........: 00-15-c5-17-58-co
Ping said
Reply from 127.0.0.1 : bytes"32 time<1ms TTL=128
Packets: sent = 4 recieved = 4 Lost = 0
Sorry....that was a little test to see on what level your skills are, you should know those things before you start deleting partitions etc.
Was the disc the original restore cd/dvd or just windows xp/vista/7 disc?
No sorry needed, I realize my understanding of these things is limited, I just cant afford to have pro work done on them. I have done seveal PCs using this disc, and most of the time there is no problem, I just got into a little somthing this time
:shakehead
I did not have the origonal disc. The computer did not come with anything. I used regular XP disc.
Thanks again you guys for taking the time to help me.
