wquiles
I am working on a diving LED head for a diver in Canada, and I am installing water-tight cable glands. These are threaded Metric 16 x 1.5, and the one in the head was easy since I started with a raw piece of Delrin:
However, the one on the canister's top, already had a cable gland - it used a tapered plumbing fitting. You can see the new cable gland here on top left, and the existing plumbing fitting on the middle. That hole is tapered:
Once I centered the hole, I drill it with the largest drill bit I have (1/2"), which is not large enough since the thread calls for a hole 37/64" in dia:
So what that means is that I need a boring head for the mill. The one to buy of course is the ones made by Criterium, but I have not been able to snag one cheap on Ebay for many months. I recently found this large monster - and I could not resist the cheap price nor the beefy construction - it looks like it could have been hand-made, it is built like a tank and everything is fitted incredibly well. Unfortunately it is designed for 1" boring bars, so I knew I would need an adapter:
So I decided to make an adapter for 1/2" boring bars out of a 1" dia drill rod piece I had around. The hole in the boring bar is "exactly" 1.000 inches, so I had to slightly turn the drill rod for it to fit:
I then drill and bored to get to 1/2" on the other side of the adapter:
I then took a piece of 1/2" drill rod and made my own boring bar:
and gave it the water hardened treatment once the edges look right to me (did everything by eye on the grinder):
Here is the hand-made boring bar and the adapter:
I then drilled and tap the adapter for set screws - I later cut those much shorter:
Here it is ready for use:
and it worked awesome:
and I was able to tap the hole as needed:
Once I finished the tapping, just as I expected, I found that the tapered hole was bigger than the new fitting on the top, so I had to bore it deeper to get to "solid" threads, while still allowing removal if later needed to be replaced:
and this is how it looks now - all possible after making my own boring bar:
Will
Will
