Follow Up -
Batt1 was put into Refresh again (3rd time) this time discharge was interrupted twice - periods were approx 2 hours, 1 hour then ~3hours (didn't see the finish).
The battery was definitely warm at the end of Charge (but not "hot") -
Testing in the charger - passed initial test and started charge (like all batteries so far) and would in this state start the Refresh without errors.
However this time my measurements were -
Batt1 1.438V; FA=8.8A -->1.414V
The FA is a noticable improvement over the 5.7A I got previously and pretty close to the flash amps I was getting with Batt3 - so perhaps the Refresh cycle has helped this Batt1?
EDIT to ADD -
As a check I put Batt1 back in the charger - it passed initial test and started charging (the bottom segment flashes 7 times then they climbed to the top segment only flashing) at under 9 minutes the charge terminated (didn't see the end) - so this looks good for the end of charge detection.
EDIT to ADD -
