terawatt
I have an old beaten-up Maglite gifted to me by a friend some years back that I've been meaning to modify/upgrade but am just now getting to it. I think the original bulb in it was an old vacuum bulb because it was incredibly dim, even on fresh alkaline cells. The reflector looked like either it had aged poorly or someone had tried to clean it, because the aluminum was thin to the point that you could see a hint of the blue plastic beneath the coating.
Years ago when I got it, I intended to mod it with an LED, but these days, I don't think it makes sense given the other options out there (better to start with something purpose built for LED). Instead, I'm feeling somewhat nostalgic and am more interested in doing a hot-wire sort of build that I never got to do back 20 years ago. The idea is to keep it incan and relatively stock looking, but get a solid boost in light output. It will just be for playing around, so it doesn't need to be very practical.
So far I've outfitted it with 2x 26650 10A protected cells, an OP aluminum cammed reflector (from Kaidomain), and a stock 6-cell xenon bi-pin bulb. That already made a big difference. It went from being a joke to something you could actually use. In terms of bang-for-buck upgrades to the bulb, it sounds like the Philips 5671 is a solid option. It's still available at prices that are at least not obscene. My understanding is that I would need a G4 bulb adapter to make this work. Does FiveMega still have ceramic bi-pin sockets available that might work for this? Besides that and a glass lens, would I need anything else to make this work?
