Sold/Expired *SPF* Surefire KX1 / 2 x Nimh / Q5 / 1100 ma / $60
BigBoy
Huntsville, Alabama
I have a USED KX1 head with 2 Madmax Plus drivers (~1100 ma) and a Q5 WC emitter. It runs on 2 Elite 1500 batteries, with a runtime of ~35 minutes. I will include 6 Elite 1500 batteries with this unit, and the 1/4 inch spacer. This has been my personal light for about 10 months.
1st class USPS shipping to North America $4.
Please post here if you want it and I'll send you a P.M. with my PayPal address.
A spacer is included to provide proper contact for the AA nimh battery. You will need to create a sleeve from cardstock to line the body and provide centering for the battery.
Re: Surefire KX1 / 2 x Nimh / Q5 / 1100 ma / $75
These are Nimh cells and can be charged on any Nimh charger. You will need a spacer to compensate for the shorter cells.
Either with this Pila charger which is a great charger
http://www.flashlightz.com/product.php/pila/bc01-ac01/?product=171829&category=1225
or this cheaper but nearly as good of Ultrafire
http://www.lighthound.com/Ultrafire...3-37-volt-Lithium-Battery-Charger_p_2279.html
You'll also need two spacers, one for each battery:D
Dan
I woulden't use either dude...they are 2/3rd A Nimh cells above ( 1.2V ) so no Li-ion charger will work.
My Bad... you're correct. Didn't see the Nimh part. I assumed it was a lithium. That's what I get for surfing the boards after being up for 24 hrs in the ER at work...:sick2::duh2::ohgeez:
Dan
Re: Surefire KX1 / 2 x Nimh / Q5 / 1100 ma / $65
Bump. This is a great light for someone who doesn't want to use lithium batteries ...
Re: Surefire KX1 / 2 x Nimh / Q5 / 1100 ma / $60
no battery body available ? :)
Will the standard P6 body work with these batteries/head?
edit: Oops, E series only I think
I'm enjoying my KX1 SOB 1000 BigBoy mod. Bob does good work.
This one will also work on a single cell (E1) body with one CR123. It may run at less than 1100mA, but will still run well.
bump for a good modder & a good light.
