A comparative impression of both - not hard numbers.
Why? The aren't the same form factor or in any way physically alike or intended sales competitors.
Answer - They both drive the SSC at reasonably high levels. 1.0A for the Malkoff and IIRC 0.82 A for the Striker SSC. So expected output isn't very different.
The modded Striker obtained through Matt works as expected. Nice switch electronics with an interesting "hold to dim" mode plus a strobe. Its only a bit more than half as long as the Malkoff 3D (and about 1 1/2" longer than an M1)and has a very nice central beam pattern similar to a less powerful Amilite T5 but with less spill. Obviously more punch than an M1, C2, P1D, etc, as expected and shown in Matt's photos. The beam is pretty near ideal for intermediate distances of 30-100', can reach further depending on environment and dark adaptation, and the dimmer protects night vision for closer use. The size is a bit large for my jacket pockets but not by much - so this may be close to a perfect light for that walk on a dark beach or in a suburban neighborhood. Too small for a club but there are better legal ways to address protection issues.
The Malkoff remains the long lance of the pair and is only a bit more than half the price of the modded Striker. Its MagLite reflector produces a very narrow spot beam that carries further than the modded Striker. Beyond 200' it is a very clear choice over the Striker but for under 100' I'd prefer the Striker beam type. A mild OP reflector in this light would make it more useful to most, I think, though perhaps at the expense of its unique feature -very long throw. If you live on a farm and need to reach across that beanfield with an LED, this has the reach to do it. And it has the stored power of 3 D cells compared to a pair of 123s.
And I suspect most of us have pounded something with a MagLite at least once, even if it was just ice in the cooler.
All of the SSC lights I've used so far (4 types) have better beams and/or color balance than the Cree lights and the obvious competitor to two favorite Fenix Crees (P1D-CE and L0D-CE because of their small form) hasn't arrived yet. Should be interesting when it does. Personally, I consider Crees impendingly obsolescent at the front edge of this technology - sort of like a "two speeds down but same generation" processor chip- and the previous Lumileds and similar "the prior generation". It becoming fairly obvious that driving the SSC at something near an amp will be needed at the front end.
(Not that prior generation stuff doesn't have a purpose in headbands for close work, and related uses. I like the X-5 in my glovebox just fine for its purpose and do not want anything brighter for that use.)
