should be:
PP (+) to LED1 (+), PP (-) to LED
2 (-), LED1 (-) to LED2 (+)
or, to have it easier to follow the electrical path:
PP(+) to LED1(+), LED1(-) to LED2(+), LED2(-) to PP(-)
with that wiring posted above, LED2 gets
reverse current.
It should be death (if it is as sensible to reverse voltage than single emitters)
Only strange thing is, that - with that wiring:
PP (+) to LED1 (+) PP (-) to LED1 (-), LED1 (+) to LED2 (-) LED2 (+) to LED1 (-)
LED 2 should not light up but You type it does. Strange.
maybe also not LED1, as LED2 just
s and all the current flows there
:thinking:
looks like the Puck has some kind of protection in, that saved both led.
Hook it up like the "revision" and both should light with full current
(when both are still intact! If one is completely dead: no light. The Puck instructions say it has a short time open load protection, so You can try that).
PS: typing this, because Your wiring will also not work with the shark, it is not series wiring, nor is it parallel.
Think of a line You draw from Puck(+) to Puck (-). When You put a led into this line, LED(+) has to look to Puck(+), Led(-) to Puck(-).
adding another led and the directions have to be the same: Led(+) has to look to Puck(+), Led(-) to Puck(-)
The difference is just the wiring:
parallel: a 2nd wire like the 1st one --> same voltage but 1/2 the current per line
series: put the led (facing the same direction as 1st one) into the line -> same current but 2 times the voltage
sorry for the long posts, in face to face communication while handling the parts, it is easy. Just by typing and reading, sounds very difficult.
[edit]
maybe its best to move You to a datasheet:
http://www.leddynamics.com/LuxDrive/datasheets/2008B-PowerPuck.pdf
figure 6 is a
Series wiring, as You have to do with the 2 P7
unfortunately there is no clear parallel wiring pic, because they always have series, too
the
typical application has a
series wiring (the 2 led at left) and a
parallel wiring with the 2 led at led (which are wired
in series again)
[/edit]
