SST-50 2D Mag Mod **29 Pics now**
Aircraft800
DFW Texas.
I wanted to do a little build for my Dad for Christmas, so I grabbed one of the new 2D Mag Rebel LED, nice light, but it needed an upgrade!
It has a beautiful new DEEP reflector, I wish I was able to use it, but it would require a new heatsink that was recessed over 1/2” into the tube, so I opted for a standard Mag reflector.
First I cut a length of electrical PVC to sleve the 3 LSD NiMh cells.
Perfect fit!
Now I need to shorten the spring to fit the upgraded cells. Next, de-anodise the tailcap with a little Greassed Lighting degreaser and a little brush and cut down the spring.
I’ll be using a Premium SST-50-W65S-F21-GJ102 for this build.
I’ll be using a special adjustible SST-50 heatsink built by LedZep.
Little Rebel, off with it’s head!
A D2Flex for PWD dimming will give me 5 levels, and temperature sensing, so I need to mod the switch for momentary action. Here how I do it.
No fancy tools here, just a drill motor and a file.
The new switches “+” contact come out so easily!
Solder on the “+” lead.
All done, not for a little testing
Time to solder up the D2Flex
It gets mounted directly to the heatsink with a double layer of Arctic Alumina so it can monitor the temperature.
SST-50 gets Arctic Alumina to the pedestal, and the snap ring gets reinstalled.
This heatsink uses a set screw to hold it in place, locate and drill the hole, and tighten it down.
It looks oh so nice in the smooth Mag reflector!
Time for a test! Wowzas!!!
This is going to make a great Christmas present for my Dad!
I had to ad some glow to top it off, and fill in the space to the reflector.
Greg G
Re: SST-50 2D Mag Mod **28 Pics**
Awesome! I like! :twothumbslovecpf
spc
Troutman, NC
Clean build, :thumbsup:
I use the hand held lathe for many things too
Aircraft800
DFW Texas.
Cool! What current is the LED seeing?
I've got to be careful, with the batteries hot of the charger (1.45V each) I was seeing 5.21A peak at the tailcap. Now that the batteries bled of that over-voltage, it reads a comfortable 3.65A on high.
:thanks: Thanks for all of the comments!! lovecpf
Al Combs
Very nice build.:twothumbs I'm sure your dad will love it.:santa:
stub
:thumbsup:Nice build, and Merry Xmas
BTW, where did you get the heat sink?
Dexter
nice work, looks great, I have been studying your pics, Im trying to work out the best way to power a cree mce in a 4d. How come you switched to C cells instead of just using three D cells?
Aircraft800
DFW Texas.
Just to keep it a little shorter. It's a 2D Mag, and I wanted to drive the SST-50 with 3.6V, so I needed 3 NiMh cells. That should under drive it most of the time, which will keep it happy.
New picture added, got my glow powder in yesterday!
ledaholic
Central Tx
Thanks Matt, I found a 15% off coupon to boot! Looks like my nephew will be getting a SST-50 Mag and charger for Christmas.
