Fulgeo
I would be concerned with running 10A through the stock Mag switch. I doubt the driver will draw very much at all when switched off...
I have run 10 amps thru the stock Mag switch in more than one of my more insane hotwire builds. Although it does work I would not trust it for a high duty cycle torch since the life of the stock switch is most probably drastically shortened. The usual trick to get by the limitations of the stock switch is to install a more robust switch of greater capacity or use a good FET. This circuit uses a FET so no worries with the 10 amps. I do trust the stock Mag switch to handle 5 amps. This driver could be used to drive a SST-50, so in that regard what I am trying to find out is could this driver be used to that end. I am not worried too much about the inactive draw of the circuit since it is so miniscule. I just have a preference to have a completely dead circuit in a torch when it is not in use. One thing I do with my mods is to back off the tail cap a few turns when they are not in use. This is easier on the batteries and springs and also acts sort of like a safety.
