Shooter21
Does don also make stainless steel models? id be interested if he does.
Stainless comes in many flavors, as does titanium, but none of the stainless alloys has properties that are comparable to Ti6-4. Some of the disadvantages of stainless alloys (specifically comparing SS316 to Ti6-4):Does don also make stainless steel models? id be interested if he does.
1. Much lower tensile strength. 75 ksi versus 135 ksi.
2. Tremendously lower yield strength. 30 ksi versus 130 ksi.
3. Almost twice as heavy per unit volume. Density of SS316 is 0.29 lbs/in³ compared to 0.16 lbs/in³ for Ti6-4. That means that a SS light of identical proportions will weigh twice as much as a titanium light.
Stainless stock is less expensive & slightly easier to machine than titanium & it is sometimes used in lower cost lights for those reasons.
Actually for almost any application Alloy 6061 aluminum would be plenty strong :devil:For almost any application though 316 would be more than strong enough.
There are over a dozen steels that contain a high percentage of tungsten and can be called tungsten steels. Most are high speed tool steels like T1, T2, T4, T5, T6, T8 & T15. Others are hot work steels like H21, H22, H23, H24, H25 & H26. Tungsten percentage varies from a low of 13% in T15 to a high of 21% in T6. All are highly wear resistant which is the reason for the inclusion of tungsten in the mix. Most tungsten steels are used to make twist drills, reamers, broaches, punches, taps, milling cutters, etc.how about tungsten steel vs titanium?
99.99% of the people in the world would pay $30 more for Ti.Someone could offer SS lights with the same design and light engine as Ti at a substantially lower price because of the material cost difference.
Here are the published Brinell Hardness figures from ASM:SS is not almost as soft as Aluminum. Stainless is steel. Not soft like aluminum used in flashlights.
Primarily because of the differences in hardness but Ti6-4 also has much greater impact resistance than either 316 or 6061.Stainless is almost as easily damaged as aluminum. Titanium endures more abuse than any other commonly available material.
pworks, you're comparing some of the hardest aluminum on the planet to stainless. What type of aluminum is you're typical aluminum light made of. I'm betting it's not T-6.
Lights that advertise "aircraft aluminum" are normally made from 6061 T-6 as it is the most commonly used alloy in the world. SF says their lights are made from "aerospace-grade" aluminum, likely meaning 7075 T-6 as it is the second most popular aircraft aluminum. Maglites are constructed from 6061 T-6.What type of aluminum is you're typical aluminum light made of. I'm betting it's not T-6.
In the readily available aluminum alloys, 7075 is the top dogMy new light is made of 7075 ...
+1its unfortunate that more companies don't use 7075 aluminum, id say hds lights should use that since they are expensive.
