Steve K
I'm not fond of the idea of completely discharging the supercap, if only because it takes a while to charge it back up and the light will be dim while it is charging. When the supercap discharges through the LED, it only discharges a few tenths of a volt below the normal operating voltage of the LED. As a side note, this is also why the simple standlight circuit is not a very effective way to use the energy stored in a supercap.
One option would be to add a switch in series with the LED to interrupt the current from the supercap. The drawback would be that bad things could happen if you forget to turn the switch back on. If the switch is at the LED, then there wouldn't be anything to limit the voltage that gets to the supercap and you could damage it. If the switch is at the supercap, then you wouldn't be charging it when you start riding again. Nothing is damaged, but you won't have a standlight when you stop.
Another option would be to throw a bag over the headlight. This would have the effect of protecting the light from the effects of the weather, sun, bird poop, etc., and perhaps also reducing the attractiveness of the bike to thieves. 🙂
