nerdgineer
Anecdotes don't tell much, so here's an informal attempt to collect statistics about people's actual experience with the Jetbeam CL-Es they've received.
The question (for those who have Jetbeam CL-Es in hand): how many good and/or bad ones did you get?
If you got a good one, check "+1 for good pile", if a bad one, check "+1 for bad pile", check "+2 for good pile" if you got 2 good ones, and so on. If you got some bad and some good, check the 2 buttons which reflect your situation. If you got say 8 good ones, you can click the +5 good and the +3 good. The poll is multiple choice (you can select more than 1 category and - late realization - the math doesn't care).
I'd like to keep this light and cheerful, unlike some other Jetbeam threads. I got 2 good ones (x2x2x3 group buy). I'm curious what other people will report.
NOTE: If your light blew when you used a 14500 Li-Ion, I request you don't use that as a reason to declare your CLE as "bad".
ANOTHER NOTE: If your threads arrived dirty but the light worked OK after cleaning and lubing of threads, I personally would still consider that a "good" light. YMMV.
