Stock Mag switch voltage and current limits
ltiu
Texas
Just wondering if anyone here knows the voltage and current limits of the stock 2D and 4D Mag switch?
What is the max current and voltage?
How high (current and/or voltage) has anyone here have run their stock Mag?
Has anyone here actually melted their stock Mag switch or any other part of a stock Mag in a hot wiring incident?
What are the symptoms of a melting stock Mag switch/Mag part?
Thanks.
I have M@g 623 with 15.6v pack using standar switch, no problem other than the switch contact became black and dirty because of the arching. No melting either since i am using Kiu's socket. 10A is somewhat borderline for Magswitch i think but you should be okay but changing the switch is better.
Voltage wouldn't be a problem for the switch it'd be the current. The handles up to 4A easy from about <10A you'll need to do some modding to the switch to lower the resistance. Above 10A even with modding it'll bottleneck your light and might possibly fail.
