Hi,
A couple of months ago I purchased a LaCrosse BC-900 charger and several sets of Eneloop AA batteries.
I was told it was best to charge the Eneloops at 200ma so that's the current I've been using.
I've noticed that on every charge, 3 batteries out of 4 finished charging while the last one kept charging for a much longer time until it finished charging.
It was always the battery in slot no. 2.
The last time it happened I tried removing the battery from the slot and placing it in in another slot, and another time I placed it in the same slot.
In both cases the display changed to "full after I had removed the battery and placed it in the charger again.
Can you tell whether it's a problem with the charger? I thought it might be a problem with the batteries but this happened with quite a few sets of batteries which makes me doubt it. Plus it always happened with slot no. 2.
Any ideas would be appreciated.
P.S. I just ordered a Maha C-9000 charger. What current is best for charging the AA Eneloops with it and also with the BC-900?
TIA,
Splashy.
TIA,
Splashy.
