Streamlight TL-3 bulb expected life(?)
chrome-addict
Just curious if anyone knows how many hours one would expect to get out of the TL-3 bulb (9v). Would a Strion bulb last longer because it's ran at a lower voltage?
The TL-3 bulb life is 30 hours. It's mentioned on the Streamlight website under Docs/Info > Fact Sheet for the product. I could not see details for the Strion.
Could you post a link please?
Not to start a new thread does anyone know where to find the potted TL-3 bulb used with weapons? I remember it being sold but can't find it.
chrome-addict said:
...Would a Strion bulb last longer because it's ran at a lower voltage?
Do you mean mounting the Strion bulb in a Strion or in a TL-3???
If you mean strion, well, I'm not sure...BUT if you mean TL-3 then NO, a bulb designed for 3.75v will flash quite fast at 9v.
I did a Google Product Search and found this at DSG arms (a company I've personally never heard of and therefore can obviously not recommend...)
It's $19.50
Does anybody know if you can run a TL-3 bulb on 2 3.7V RCRs? Would this effect bulb life/runtime/brightness? To me, it seems like you may be sacrificing some brightness for bulb life, because the bulb would be underdriven at 8.4V at the start, and end up at around 7.4V.
I have heard of people using a TL-3 bulb in a TL-2 with two 3.7 rechargeables. I have never tried it myself.
i run my stock tl-3 bulb w/ 2x17500's and they last longer and maintains brightness longer than using the 3 cr123a's.... a 17500 is 3.7 volt Li-Ion also... but it has higher capacity than a rcr123a... plus w/ the two 17500's, you don't need a dummy cell that may add additional resistance to the circuit.
The TL-3 bulb in a TL-2 on 2 RCR123 3.7V cells is going to perform about the same (as far as brightness goes) as it would on 3xCR123 in the Tl-3, but you loose a lot of runtime. The TL-3 bulb in the TL-3 running on 2x17500 is slightly brighter through the run with similar runtime as 3 CR123, but the initial voltage is easier on the bulb, so the chances of instaflash are actually reduces a bit, bulb life stays pretty similar.
