Suggestion for a good car power inverter
leprechaun414
Connecticut USA
I would like to get some suggestions for a good power inverter for my car that can run a coffee maker, and some other devices with a high power consumption. I know I am looking for a high power so I guess I am looking for a good brand with the best features. Most outlets, thermal protection, shut down protection, etc. I hope that someone has one that they love and can suggest. Thanks
Names, model # and site links a +
I've been wondering what's a good brand of power inverter too. I'd be using it during power outages though off a separate old car battery (charged of course 🙂). Last time at Costco there were 2 different Xantrex models, one was a 1500w model which I think was like this one. The other was a smaller wattage one that I can't remember the output for....1000w maybe. There was a "*" on the corner of the item marker tag with the price and item number but of course, can't remember what the star means. Anyone have experience with those power inverters?
There are two basic kinds of inverters; true sine wave and modified sine wave. True sine wave is what comes out of the wall. Modified sine wave is basically a square wave with the corners smoothed a little. Most stores only carry modified sine inverters because they are a lot cheaper.
Your coffee maker won't be able to tell the difference. If you are going to run any sort of audio, video or computer devices, you can tell the difference. Devices tend to run cooler and there is a lot less audio and video "noise" with a true sine inverter.
There are several makers of true sine wave inverters. Here is a Xantrex one. Search for "true sine wave inverters" to find others.
my coffee makers almost equivalent to my hairdryer, which runs in excess of 1600 on full bore
inverter ratings only go as high as around 600 watts continuous AC before its no longer below the cigarette plug fuse threshold and has to be wired directly to the battery of your vehicle...which can be a pain in the @#$%
if your looking for something that will brew coffee on your rig, consider investing in something like this "12V coffee maker"
a few companies I've heard very very good things about include Exeltech and Xantrex
my personal old and reliable comes from vector commonly available in lowes or homedepot but the higher wattage ones will require special order
Xantrex - formerly Trace are IMO the best inverters made hands down. I had a 4000 watt inverter on my home in California and it worked perfectly as a whole house power backup system. That model was true sine wave. These are heavily used in Solar systems and other systems needing high reliability and good life span.
I have the costco 1000 waat Xantrex inverter. I coupled it with a deep discharge battery and a charge maintainer battery charger. This setup is able to provide up to 1500 watts for a few minutes, 1000 continuous.
It's almost never worked as I wanted it to.
I'd had it almost 2 years when we had a power outage at 5 am. The beeping UPSes woke me, so I powered on the inverter, ran an extention cord 30 feet to the coffee maker and within a minute the UPS was beeping. I assumed it was the overload alarm. It shut off before the coffee was finished. I had almost 1/2 pot of coffee.
Later, when we had power back and time to investigate, I realized that pulling around 100 amps from the battery (to get 1100 watts to the coffee maker) was murder on the battery. The charge maintainer I'd had it hooked to was inadequate, and when I checked the water I was shocked to see that the cells were dry. The charger had boiled off the water. The constant beep was a low voltage alarm, not the overload that I expected.
A new battery was not in the cards; I topped it off and got it back into service, but it never recovered from the high curent with inadequate electrolyte. I bought a 4 cup coffee maker that pulls only 500 watts or so, and used it during the next outrage. The low voltage alarm came on in only 10 minutes, so I recycled the battery and set the inverter aside in case I ever need it again.
I've since bought a gasoline based battery. Well, it converts gasoline to electricity. The 6500 watts continuous, 7500 peak, electric start generator will handle 6 coffee makers at once.
I figure the use I got from the charger + battery + inverter came to about $50 an hour.
Daniel
I'm assuming your using a coffee maker to scale the load you plan to put on your inverter and not actually making coffee on the road are you?
back 10 years ago when gas was $0.89 a gallon premium inverters were expensive but it wasn't expensive to brew coffee on the road...now I wouldn't leave my car idle for 5 minutes, let alone the 10 mine needs to brew a good 4 cups of coffee🙄
Was at Costco again today and got the prices of the 2 Xantrex inverters they had there. One is the Xpower Inverter 1500 for $86.99 and the other one is the Xpower Inverter 1750 Plus for $135.99. Is the Plus model that much better than the normal one that it justifies the higher price? I'm new to this kind of stuff but it'd be nice to be able to power stuff without a generator next time the power goes out. 🙂
It doesn't look like the 1750 Plus model has an air compressor on the side like my Plus model does. :thinking: Beats me.
The two main differences:
- Easy to read digital display indicates DC battery voltage
- LED bar graph displays output power
And an extra power socket.
Yeah, no air compressor on that one. Would those 3 features along with 250 more watts be worth the $49 higher cost? Is the plus model better built than the regular one? Not directing these questions just at you TorchBoy, to anyone with experience with these. 🙂
Of course, it's a coffee machine pimped out by Monster Garage! :thumbsup: Just looking for a decent to good inverter to use with old car batteries during a power outage.
Dad picked up a Tripp Lite model decades ago for running a heating pad and I still use the very same unit today for various AC appliances. Looking at the current line up, the PV375 is about the biggest I'd keep loose in the car:
Course, they do have bigger ones:
http://www.tripplite.com/products/inverters/sizing_guide.cfm
This one's a mear 7000 watts: :devil:
APS3636VR%2Ejpg
