Z
z_lightheaded_1
Guest
I just took apart my old spotlight because the bulb blew (and it's a peice of junk anyway).
It's a Vector VEC192 (supposedly 20 million CP)
Not this newer model:
http://www.compactappliance.com/Vect...c=SHOPDISCOUNT
But this version:
http://www.redhillsupply.com/content...light-info.htm
The H4 bulb inside is a 12V 130/100 Watt car bulb, which I'm guessing is about 8-10 Amps (calculated).
The battery source is unmarked mostly, but it's two 6 Volt cells tied together...I couldn't find it on this page:
http://en.wikipedia.org/wiki/List_of_battery_sizes
So I assume it's a non-standard battery pack, probably made just to power this type of light.
So I want to replace the H4 bulb to use when I go on camping trips...but I don't think an H4 has a very long shelf life with this thing.
What would you suggest replacing it with?
Are there any HID or LEDs I could buy that would work instead of the 12V/130W H4 bulb?
But this version:
