What do you think a reasonable distance that the XR-U would be useful for outside.
For a XR-U with MC-E i would be in!
:twothumbs
I believe the merit is in driving four emitter dies at lower, more efficient current levels, instead of driving one emitter die at a higher, less efficient current level. Case in point: my Arc6 MC-E is much brighter than my Arc6 K2, and it runs cooler too.I don't see the merit here. It might be a different story if the MC-E were driven at its full potential but that isn't going to happen in this host. I haven't done any comparisons but I suspect that a XP-G in the original SunDrop driven by the current 3S converter I am using would compete favorably against the one proto I made with the MC-E in terms of beam pattern and flux.
Not R5 -- I believe that is only a G-die bin -- but either Q5/R2 or Q3 as far as I can tell. Driving them in-series is safer, I suppose, but since the four dies share a single thermal sink, that should mean the dies will always remain at similar temperatures to avoid a thermal runaway condition, as long as none of the dies has a vastly out-of-spec Vf. I think the thermal runaway condition is much more of a concern with multi-die setups where the dies are contained in separate packages where they can't keep each other at the same temperature.Does the MC-E have 4 R5 flux bin dice? These dice should be driven in series but Paralle seems to be just fine and especially if the current is below spec, significantly.
That is true, but at the same time the Nichia 083s use six dies, so the impact to the beam from using an MC-E is debatable.The image being projected is not the same with 1 VS 4 dice and even behind the lens which is not focused, there is a difference.
Yes, and I knew that would be the case. One of the main reasons I went with an MC-E for my second Arc6 mod (aside from the fact that I actually have a few on-hand) is because even at 1.4 amps I would be driving the four dies at their recommended current (350mA, spot-on) instead of at their max current (700mA). Aside from whatever improved efficiency each MC-E die might have over the K2 die, there was also improved efficiency to be had by not driving those dies very hard. As for whether they would be still more efficient at half that power, I can't say for sure, but I think the answer is "yes'. If you happen to come across some spare time, it might be a fun experiment to transplant an MC-E onto a Haiku XR-E light engine and see whether it's substantially brighter than the stock XP-G.I would guess you are driving the K2 which is an inefficient LED relative to others, at close to spec. In my virtual comparison, I would be driving an XP-G well below its max current and the dice of the MC-E below theirs.
Well, I can't comment with any authority on the impact that public speculation might have on your business, but it's still interesting to hear where you come out on issues like these. It gives me a somewhat better understanding of why businesses make the decisions they make.In retrospect, I should have avoided any comments.
Thanks Bass, scout24 also informed that it was at its full output. For only 46 lumens it looks pretty good but it may not serve my purpose after all it would be fine for many uses but in the end I would just use my Haiku more and it would become a shelf queen and I only buy what I will use. Thanks for the info.Per-Sev, That's the Sundrop XR-U on Max; it doesn't get any brighter than 46 lumens.
